350Evo 3.9 installed impression
#62
OGPremierMafia
![](https://my350z.com/forum/images/ranks/premier.gif)
on
YES both should still work, the car as i believe has a speed based cruise control and will only hold CC up to 90 mph the only difference is the rpms at each given speed... So maybe try to reset the ecu and relearn the Throttle? See if that helps.
#63
on
I've put on over 15k miles with my 350evo 3.9 gears with no problems - VDC & cruise both fine & always have. I do change rear gear oil twice a year.... maybe a little overkill there, but it's all good
![Smilie](https://my350z.com/forum/images/smilies/smile.gif)
#65
on
so what exactly are the "other install parts" people keep talking about. If i ordered the 3.9 FD for my car it comes with the ring and pinion and i have to buy something else also? Hope i don't sound dumb for asking this.
#66
on
Pinion nut, pinion crush sleeve, pinion oil seal, and shims.
Some people will also choose to replace the bearings and bolts in there as well.
#67
on
Originally Posted by faris13
don't know if this was directed towards me but...I mentioned that it does not reduce top speed on the car for those with the limiter still in place. Yes our gears are theoretically able to hit 185.6 stock and the 3.9 reduces it to 167.6. So if you still have the limiter on the car then the 3.9 does nothing to the actual top speed you can reach. Now if you want to get up to 170+ you need FI, and if you go FI then the 3.9 gearing would probably not be a good idea on the car...you would be better off with the stock final drive or the auto one.
![](https://my350z.com/forum/images/smilies/icon14.gif)
#70
Originally Posted by Havok_RLS2
Anybody know a location to have then installed in Maryland and the cost?
#71
Originally Posted by helldorado
AAM is doing mine with a Quaife. So I can't help you on the price portion. If you're going to do the gears, you might as well take advantage of having the unit in pieces and put in a better differential if you don't have one already.
![](https://my350z.com/forum/images/smilies/icon09.gif)
#74
I'm not sure if I envy or pitty you.
Something like.... Yayyyy.....Boooooo.
Hopefully they're giving you the hookup on the install. ![Big Grin](https://my350z.com/forum/images/smilies/biggrin.gif)
![](https://my350z.com/forum/images/smilies/icon08.gif)
![](https://my350z.com/forum/images/smilies/icon43.gif)
![eekdance](https://my350z.com/forum/images/smilies/eekdance.gif)
It'll be fine, we came to an agreement on all the terms before even ordering a single part. I have no doubt in their technicians' ability to do the work, its more a matter of I'm the guinea pig for determining how long the job will take so they can estimate the job as accurately as possible for future customers.
#75
OGPremierMafia
on
Update, I've had my FD now for 15K miles and love it still, am probably going to do a FI setup soon and am looking forward to seeing the awesome accel!
Only Complaint is not buying the ATS LSD when i had the FD installed!
#76
#77
Someone did manage to get the 3.9 to work with the ATS LSD though after a lot of frusturating labor and $
#79
Originally Posted by sentry65
ATS LSD won't work with the 3.9 (or 3.3), but the great news is they do have a fix. And that fix is to use the 3.5 final drive
....yeah it said so right on their site
![](https://my350z.com/forum/images/smilies/icon38.gif)
Then again, I got the Nismo 3.9 since we were having clearance issues with the 350EVO one. Who knows if that makes a difference?
#80
OGPremierMafia
on
Frank at AAM is a perfectionist, it was 1 mm off and he wanted it exact. I'm ok with that. ![](https://my350z.com/forum/images/smilies/icon38.gif)
I am not familiar with the Nismo 3.9FD... do you have any more info on it!
my friend is "ALL" I want ever nismo part 'idis' so that would be a great mod for his PPW!
