best light weight flywheel regardless of price?
Old Jan 8, 2006 | 08:50 PM
ghost11's Avatar
ghost11
Default best light weight flywheel regardless of price?
i'm keeping my stock clutch for now, so it needs to be compatible
Old Jan 9, 2006 | 12:31 AM
JETPILOT's Avatar
JETPILOT
Best.....
Lightest? Quietest? Best for drag launches? Best for daily driving? Best for?
Respect
JET
Old Jan 9, 2006 | 12:46 AM
Dubai's Avatar
Dubai
Jwt
Old Jan 9, 2006 | 03:42 AM
PoWeRtRiP's Avatar
PoWeRtRiP
jwt should serve ur needs. however i must ask why dont u replace the disc while its apart? the amount of labor it takes to put a flywheel in is not simple nor cheap (if u go to a shop) to just install half of the consumable parts in your clutch, why not put in a disc as well?
Old Jan 9, 2006 | 03:53 AM
SpeedRcr's Avatar
SpeedRcr
i like my rps setup...
Old Jan 9, 2006 | 11:38 AM
rbfd's Avatar
rbfd
Tilton, i love it, dropping 40lbs of rotating mass off my car helped in ways i cant begin to explain, although the occasional stalling when i getting started on hills sucks.
Old Jan 9, 2006 | 11:48 AM
PoWeRtRiP's Avatar
PoWeRtRiP
tilton is not compatible with stock clutch
Old Jan 9, 2006 | 11:59 AM
rbfd's Avatar
rbfd
true, i didnt consider that
Old Jan 9, 2006 | 03:43 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
all are very comparable
Old Jan 9, 2006 | 05:16 PM
Mr_Drifter's Avatar
Mr_Drifter
JUN-----no chatter, works with stock clutch.
Old Jan 9, 2006 | 06:45 PM
ppith's Avatar
ppith
If you're into tracking/auto-x, go for Stillen's flywheel. It has a little chatter, but puts a huge smile on your face when you heel-toe downshift and the revs jump oh-so-perfectly! I have the stock clutch with the engagement changed so that it's not as high. Stop and go traffic is definitely not a problem though you do have to get used to applying less pressure to the gas pedal to bring up the revs. Of course, if you drive your car hard enough it won't keep up with a racing flywheel. But that's the compromise between track and street flywheels.
Old Jan 9, 2006 | 07:48 PM
ghost11's Avatar
ghost11
i don't track the car, so i don't need anything too extreme, it's not my daily driver, but i still don't want to sacrifice it's drivability
Old Jan 9, 2006 | 07:49 PM
ghost11's Avatar
ghost11
stupid question: what is chatter? i suppose it has something to do with the sound?
Old Jan 9, 2006 | 11:02 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
It shouldnt have anything to do with price...
But actual performance / driavality...
If you dont care about driveablity ....
Tilton... 8lbs flywheel 8lbs clutch.. 16lbs total... 7.25" diameter clutch...
http://www.performancenissanparts.co...&Submit=Search
right click and save as...
http://members.aol.com/performancenismo/tilton.avi
my car with only Tilton clutch and NISMO exhaust... no other mods...
Old Jan 9, 2006 | 11:04 PM
Jason@Performance
Performance Nissan
If you want an option taht is going to be fully streetable to drive like a stock clutch...
For the money (Under $1000) the lightest option is JWT Flywheel and NISMO Clutch... the NISMO clutch is lmost 2lbs lighter then the JWT clutch...
The next is the EXEDY hyper carbon series clutches... They are smaller diameter then stock, use their own flywheel, and slip easy when cool (daily driving) and when heated up grab like mad!
350z clutch options...
Old Jan 9, 2006 | 11:42 PM
Jason@Performance
Performance Nissan
oh and keepign your stock clutch... you will spend more money replacing the clutch later on down the road then changing the clutch and flywheel at the same time...
its close to the same amount of labor to replace the clutch as it is for a new clutch...
Old Jan 10, 2006 | 04:51 AM
Z1 Performance
Former Sponsor
and FYI JWT=Fidanza
Old Jan 10, 2006 | 08:32 AM
Jason@Performance
Performance Nissan
aasco = _ _
hehe
Old Jan 10, 2006 | 08:37 AM
Z1 Performance
Former Sponsor
correct although I think the ring gear is different
Old Jan 10, 2006 | 10:14 AM
Chebosto's Avatar
Chebosto
is stillen flywheel still = Mueller ?
