Are the axles considered powertrian
Old Jan 27, 2006 | 09:31 PM
pope's Avatar
pope
Default Are the axles considered powertrian
I just developed the axle clicking problem and my 3 year mark was last month. Is this covered under the 5 year powertrain warranty?? I really dont want to pay for this out of pocket. if i dont have to.... that would be money that isnt going into my "VRT fund" and i dont want that.
Old Jan 27, 2006 | 10:24 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
i would have to say yes, drivetrain should include engine,trans,rearend. plus there was a tsb on that, so it might not even matter. all they do is pull out axle put diff grease in and rotate axles 1/2 turn. heres the bulletin you can take to dealer. BULLETINNTB04065B hope that helps you out. the parts are 2 cotter pins pn40073-0L700, 12 washers pn08915-2401A, 12 bolts pn39606-22P00 and 12 nuts pn39607-03P00. i included that in case they wont cover it you could do it yourself and save$$$$
Old Jan 28, 2006 | 05:23 AM
DavesZ#3's Avatar
DavesZ#3
Yes they are. From the warranty book:
■ POWERTRAIN COVERAGE
• The Powertrain coverage period is 60 months or 60,000
miles, whichever comes first.
• This warranty covers any repairs needed to correct
defects in materials or workmanship.
• Powertrain coverage applies to components listed below,
supplied by Nissan except for those items listed
under the caption “WHAT IS NOT COVERED”.
ENGINE
Cylinder heads and block and all internal parts, rocker
covers and oil pan, valve train and front cover, timing chain
and tensioner, oil pump, water pump and fuel pump, fuel
injectors, intake and exhaust manifolds and supercharger,
flywheel, seals, and gaskets.
TRANSMISSION AND TRANSAXLE
Case and all internal parts, torque converter and converter
housing, automatic transmission control module, transfer
case and all internal parts, seals and gaskets, clutch cover
and housing, and electronic transmission controls.
DRIVETRAIN
Drive shafts, final drive housing and all internal parts,
propeller shafts, universal joints, bearings, seals and gaskets.
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
Juztin
Nov 22, 2015 07:03 AM
Alexreyes
Sep 30, 2015 11:30 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
