engine breaking up at 2,500 RPM
Old Feb 4, 2006 | 06:18 AM
gaithersburg's Avatar
gaithersburg
Default engine breaking up at 2,500 RPM
The other night i was driving my 2004 350z the engine starting "bucking" very badly each time i approached 2,500 RPM, regardless of gear. I had been driving the car for about 30 minutes prior to stopping for dinner with no sign of any rough engine. After driving home local roads i let the car sit for a day, after which the car ran as if nothing happened. I have approx. 31K miles and since September have only driven the car once every 4-7 days. Since it happened in every gear and almost exactly at 2,500 RPM i assume it was the engine and not the clutch. Any idea before i go to the dealer?
Old Feb 4, 2006 | 06:22 AM
westpak's Avatar
westpak
SFZCC
It sounds like your ECU has gone into limp mode probably too many possibilities but it should start fine after having it off for a while if it was a one time issue, if it continues to happen check for codes or justtake it to the dealer, not all codes set off the check engine light.
Old Feb 4, 2006 | 07:01 AM
gaithersburg
thanks, are there specific situations which would cause the ECU to do this?
Old Feb 4, 2006 | 12:09 PM
Nexx's Avatar
Nexx
something stuck in your intake?
Old Feb 4, 2006 | 03:00 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
if you have a cai on, make sure mass air wiring isnt rubbing on the hood. it might have just wore through wire? it's worth checking.
liqalu04
Jan 2, 2022 12:58 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Fixxxercask
Nov 9, 2015 11:10 AM
