Reflash or Utec?
Old Mar 3, 2006 | 01:08 AM
NiSmO21z's Avatar
NiSmO21z
Default Reflash or Utec?
Is the Utec that much better then a reflash. What gives out more power? I'm not to familiar with the Utec. Would it be stupid to get a reflash, or should I just wait to get the Utec? Opinion? How does it work?
Old Mar 3, 2006 | 01:45 AM
Mike Wazowski's Avatar
Mike Wazowski
Utec will cost you double what a flash will. I would say if you are only lightly modded a flash would be beneficial, but if you have a lot of NA parts to go with the Utec to get the most from everything. If you go with the flash you should take a long drive down to AAM so they can do it there. If you mail it your car will be down a few days and the flash may end up being to rich or to lean and you would need to send it back. I have seen posts from people on the board that had to send their unit back to Technosquare several times until they got the flash right.
Old Mar 3, 2006 | 03:29 AM
wperdigon's Avatar
wperdigon
I can tell you that I'm not very impressed with the Technosquare results - I would say go with the AAM reflash -
Old Mar 3, 2006 | 06:45 AM
zzzya's Avatar
zzzya
A reflash is best done in the shop while on a dyno as is the UTEC. Dyno time costs money and so does a custom reflash. In the end the UTEC offers a more flexible solution as there are not many places in the entire country that can reflash the ECU so your odds of a local company being able to tune the car on the dyno is much higher with the UTEC. Also, if you are interested enough you can easily learn how to tweak your tune on the road with a laptop with the UTEC, which is not possible with a reflash. This is nice since adding new mods at a later date may require some additional tuning.
Old Mar 3, 2006 | 07:16 AM
titanjc's Avatar
titanjc
Aren't the TS and AAM reflashes the same?
Old Mar 3, 2006 | 11:25 AM
KhanMan's Avatar
KhanMan
Different updates?
Old Mar 3, 2006 | 11:37 AM
MOTOP's Avatar
MOTOP
From what I hear, going with UTEC negates all the benefits of factory tunning. IE, you'll have to tune the car from the scratch. I want to see some Emanage Ultimates on NA cars. I'm going to discuss this with Tedd at SP tomorrow.
Old Mar 3, 2006 | 11:58 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
If you only have bolt ons, it's not really worth the money to go with UTEC IMO. It is a better tuning device, but you do not need to adjust or tune that much with bolt ons, even if you go with things like cams etc... It depends on how modded you are. I would recomend the reflash, ESPECIALLY for the money, unless you're planning on hardcore engine work etc...
Old Mar 3, 2006 | 12:07 PM
JisNis's Avatar
JisNis
There was talk about the UTEC gaining 10-15 hp ontop of the Reflash. I think its worth the investment. You can always use it for FI or some crazy N/A setup. With the reflash dont you have to get it flash for every mod you add on after the reflash? How much would that cost compared to dyno tunning for the UTEC? Another plus for the UTEC, you can store multiple maps for multiple setups (say race fuel).
Just my .02 cents.
Old Mar 3, 2006 | 12:19 PM
BobbyRitz's Avatar
BobbyRitz
Just my .02 cents.
I said this. I'm NA and purchased the reflash first. If I had it to do again, I would skip the reflash.
UTEC gives the tuner greater ability to tune the car. As I understand it, a reflash is designed for z's with an intake and exhaust. I have other bolt ons and UTEC allows me to dial in a/f and timing. Plus, it's widely advertised that not all Z's are created equal. I enjoy knowing that MY Z is tuned to synchonize all bolt ons that I've added.
Plus, as stated earlier, UTEC allowed multiple maps to be stored. I have 4 maps. Two of them are 100 octane maps.
My plan is to go FI. That said, UTEC was a no brainer for me. Up to 20 additional whp is a nice gain on a car that comes highly tuned from the factory.
Old Mar 3, 2006 | 12:22 PM
showstoppertk's Avatar
showstoppertk
I guess someone like myself stuck in hawaii where I can't get a dyno tuned reflash because obviously neither technosquare nor AAM are here nor are there any tuner shops that I know of that have any experience tuning with the UTEC (much less know what it is) is pretty much SOL huh? I've heard too many bad stories from guys who have done their reflash by mail to want to walk down that road. I guess the best option for a bolt on guy like myself is to get emanage blue (which shops here hopefully do have extensive experience with) and have they dyno tune with that.
PS: sorry for the thread jack.
Old Mar 3, 2006 | 12:27 PM
BobbyRitz's Avatar
BobbyRitz
I agree with your post with the exception of ECU reflashing involving a dyno. It is my experience that this isn't the case.
Old Mar 3, 2006 | 12:29 PM
BobbyRitz's Avatar
BobbyRitz
Wicked Machine Racing in Honolulu is an authorized UTEC dealer.
Old Mar 3, 2006 | 12:33 PM
showstoppertk
wow, I didn't know that. too bad they haven't install one on a Z yet, nor do they have a dyno. thanks though.
Old Mar 3, 2006 | 12:44 PM
BobbyRitz's Avatar
BobbyRitz
UTEC is a piggy back. It uses the ECU for idling (as I understand it, a difficult set of parameters to replicate on a stand alone). Remember factory tuning does not account for additional air in (through an intake and spacer) and exhaust out (through larger y pipes and more breathable aftermarket exhausts).
I'm by no means an expert, but this is what I've gathered along the way.
Old Mar 3, 2006 | 01:03 PM
yeperra's Avatar
yeperra
Any one have a link for the UTEC?
Old Mar 3, 2006 | 01:09 PM
TheCajunStyle's Avatar
TheCajunStyle
www.turboxs.com
Old Mar 3, 2006 | 06:44 PM
zzzya's Avatar
zzzya
Well, start reading some more. The only guys who have been truly successful with the reflash that had any serious NA mods had to get the reflash done at the facility and it is definately best done while on the dyno, just ask AAM. I tried to mail my ECU back and forth to TS for over a year, yes over a year and we could not get it right, even with a wideband and A/F readings. We ended up spending more on actual shipping costs than the reflash itself!!!! The UTEC or EU are going to be better options than a reflash for nearly all users. Unless you have AAM in your backyard to change the reflash everytime you need it done, the other options are much more flexible and offer many additional tuning options across the country. If you have to start sending the ECU back and forth the cost starts to go up very quickly. AAM will do a custom reflash at their facility on the dyno, but that is extra $$$.
Old Mar 3, 2006 | 07:05 PM
steela2110's Avatar
steela2110
UTEC... enough said
Old Mar 4, 2006 | 07:57 AM
yeperra's Avatar
yeperra
Thanks cajun
