Who has the highest hp/tq for NA auto?
Old Mar 8, 2006 | 11:04 AM
dorkstar's Avatar
dorkstar
Yes.
Old Mar 9, 2006 | 10:37 AM
mgl's Avatar
mgl
i dyno'd 235whp and 251tq.
mods at the time of dyno were labree resonated test pipes, jic ypipe, crawford v5 plenum.
Old Sep 30, 2006 | 08:16 AM
cvt's Avatar
cvt
old thread but just wanted to list out my experience
mods:stillen TD, K and N typhoon intake, Motordyne iso therm spacer 5/16", kjr pulley
4th gear: 228whp
3rd gear: 242whp
Old Sep 30, 2006 | 12:05 PM
99atlantic's Avatar
99atlantic
me - 565rwhp/545rwtq
Old Oct 26, 2006 | 11:04 AM
ZLadie2000's Avatar
ZLadie2000
Hey will pulleys make difference on a 5at??
My goal is 290 rwhp on my 5at... I have the mods in my sig and plan on getting a Utec and Cams. Ive heard hfc's just make the car louder, headers just make the car louder (it's my daily driver-heard this from Wired 24/7), and pulleys dont make much power at all on an 5at....
Old Oct 26, 2006 | 11:12 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I never said headers don't make power...
just that I don't want them on my car personally.
Old Oct 26, 2006 | 11:14 AM
ZLadie2000's Avatar
ZLadie2000
^^ not worth the trade off huh? power gains versus, decibel gain of sound? I feel ya, I'm a daily driver Z too.. I dont know if it's worth the cost and labor...on the other hand cams are more worth it in my opinion, no gain in noise levels, however 17rwhp sounds good to me....(im picking up a good deal on a used set).
Old Oct 26, 2006 | 11:20 AM
cvt's Avatar
cvt
17whp is generous for cams...i've seen dynos of mild street cams (the ones for 262 duration) for only13-15 on a 6speed...a 5AT will be lower
Old Oct 26, 2006 | 11:22 AM
ZLadie2000's Avatar
ZLadie2000
^^ why will it be lower for 5AT? Drivetrain loss is higher? Whats the percentage drivetrain loss for 5at?
17rwhp was an estimate from Sharif for the Tomei 268 cams.
Old Oct 26, 2006 | 11:38 AM
Ghost 350z's Avatar
Ghost 350z
Geez why the big drop in power(almost the same mods, very diff. numbers in this thread)---->shows what a good tune will do
Old Oct 26, 2006 | 03:00 PM
cvt's Avatar
cvt
268 are pretty aggressive...be aware that the more aggressive the cam the more hp/tq sacrificed in the lower to mid range to aquire top/peak power. on dynos even mild cams like nismo or jwt lose a little down low to get peak hp up top.
percentage of drivetrain loss is kinda fluctuates. i've seen stock 5ATs dyno at 210 whp which would be a 27% drive train loss to 220whp stock which would be around a 23% drivetrain loss (5ATs rated at 287hp to the crank)
Old Oct 27, 2006 | 10:49 AM
Nismo 350z's Avatar
Nismo 350z
Originally Posted by Mr_pharmD
Anyone?? I always hear ppl making 300hp with MT so is there anyone above 250hp with auto?
I would like to see these people you hear about making 300whp NA. Im a 6spd myself and only dyno 260whp 240wtq.
Old Oct 27, 2006 | 10:50 AM
Nismo 350z's Avatar
Nismo 350z
I gained 10whp from my headers and 8whp on my HFC's. Didnt just make my car louder.
Old Oct 27, 2006 | 10:53 AM
Cannysage's Avatar
Cannysage
I gained 14 whp from exhaust, testpipes and pulley. I'm at 284whp on dynapack
correction: 20whp
Old Oct 27, 2006 | 12:56 PM
cvt's Avatar
cvt
correction: 20whp
isn't it 284 to the hub? not the wheel?
Old Oct 27, 2006 | 02:00 PM
Cannysage's Avatar
Cannysage
it's still read it as whp. they take off the wheels and supposedly, you get more of an accurate reading.. especially when you're measuring your gains..
Old Oct 27, 2006 | 04:46 PM
350Zzzz's Avatar
350Zzzz
Professional
The dynopack, which measures at the wheel hubs, tends to generate readings without load and usually produces higher results; unless it's calibrated with load in the equation.
As long, as the whp readings, base and after mod is done on the same machine the gains are valid.
But still it is not feasable to compare dyno results, when load, weather, environment cooling factor, etc can effect the readings.
G
_______________________
Old Oct 27, 2006 | 07:37 PM
  #38
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
G
Yes, but no one seems to realize it
Old Oct 28, 2006 | 11:29 AM
  #39
roncfpz's Avatar
roncfpz
In general, it's reasonable to use a 20% reduction factor for the 5AT.
Old Oct 28, 2006 | 03:14 PM
  #40
whtz05's Avatar
whtz05
my car dynoed 219whp stock.
