UTEC tuner in Texas?
Old Mar 12, 2006 | 02:58 PM
SmokyTyrz's Avatar
SmokyTyrz
Default UTEC tuner in Texas?
I realize this is a double post from another section (Texas local), but I wanted to hit a larger audience, in a more specialized section. So, apologies in advance to the mods.
Anyone know of a reputable UTEC tuner in Texas? I am near Dallas, but will drive a bit.
Still contemplating the UTEC or not. If I have to drive out of state then it isn't worth it. But I would like to take better advantage of my mods. I haven't had the first dyno yet, but as with most other setup on the OEM mappings I suspect it leans in the upper rpm band. Obviously I'll confirm this at the first opportunity before moving ahead with any engine management piggybacks.
I know a couple local places support the eManage systems, but that just seems like such a generic approach. And very bottom-up. The UTEC seems a bit more specialized, even if it is used on several different cars from different manufacturers. And it is a better overall "solution" from an implementation perspective.
Anyway, any tips on reputable and experienced UTEC tuners in the state would be a great help.
Thx
-Smoky
Old Mar 13, 2006 | 06:20 PM
Jokestrap's Avatar
Jokestrap
SGP in Houston...
Old Mar 13, 2006 | 06:23 PM
Nexx's Avatar
Nexx
not sure if they do but you might want to give Jotech a call. http://www.jotechracing.com/
Old Mar 14, 2006 | 06:47 AM
SmokyTyrz's Avatar
SmokyTyrz
I called SGP and the guy I talked to didn't know what I was talking about when I asked about the UTEC. And Jotech doesn't do it either. They are only just now getting on-board with the Unichip. But Jotech uses mostly eManage right now.
Thx anyway guys
-Smoky
Old Mar 24, 2006 | 08:44 AM
Jay'Z's Avatar
Jay'Z
Question weird..
you would think since sgp sells it they would know how to tune it.. i emailed sgp about the setup i wanted(ati pro charger wit utec management) they recommended greddy ultimate for some reason .. I really want utec because its plug and play .. but i may have to do greddy ultimate if sgp recommended it .. (i have plenty other mods too and im sure ill make 400 hp .. I just wanted to focus on FI/management setup with them and see what they recommend)
UPDATE IS SGP DOES TUNE UTEC ON 350Z EXCELLENT I MIGHT ADD!
Old Mar 24, 2006 | 05:48 PM
350xfire's Avatar
350xfire
Old Mar 24, 2006 | 05:49 PM
350xfire's Avatar
350xfire
The one thing I like about Greddy is the dual mode switch. This way, you can cruise on "low" and turn it up with a flip of a switch. May help to cut down on engine wear...
Old Mar 24, 2006 | 06:25 PM
Gman2004's Avatar
Gman2004
from my understanding SGP has not been able to get the UTEC working well on any of the installs they have done. they are recommending the EU because they don't want install something they can't get to work properly. I heard that SGP had an old software for the UTEC so I don't know if that's why they couldn't get it working right.
SGP tuned my car with the EU and it ran great. When I got into Florida the hotter weather threw my tune off. Mark flew out to Miami installed the HKS FCON and retuned my car. It runs great now!
Old Mar 24, 2006 | 06:29 PM
350xfire's Avatar
350xfire
SGP tuned my car with the EU and it ran great. When I got into Florida the hotter weather threw my tune of. Mark flew out to Miami installed the HKS FCON and retuned my car. It runs great now!
Is the FCON able to adjust for any weather conditions? I heard that is a completely stand-alone system, right? How much are those going for?
Old Mar 24, 2006 | 06:31 PM
Gman2004's Avatar
Gman2004
Yes the FCON is full standalone and acts just like a OEM ECU. It has it own air temp sensor and eliminates the maf. It will set you back about $3,400 with all harnesses, sensors, and knock amp.
Old Mar 25, 2006 | 03:16 AM
Jay'Z's Avatar
Jay'Z
Thumbs up
thanks for the info fellas! but FCON sounds good but it would burn a hole through my pocket all the way down to the basement ...lol
im gonna go with the greddy e u..
350xfire i like what you said about the switching into cruise mode to lessen engine wear too!!
and oh Gman, wow does it make that much a difference in the climate your driving in ?? wow cause i move around alot in the army , i hope i dont have to keep gettin tuned all the time ..
Old Mar 25, 2006 | 05:50 AM
Gman2004's Avatar
Gman2004
Climate will affect your tune. The good news is that the EU has an auto tune feature for the a/f ratio. Have your tuner show you how to use it and if your a/f's get thrown off then you can auto tune. Once your tuner sets the timing you won't have to mess with it. I did not auto tune cause when I had the EU because I didn't know how to use it and anyway when you are as modded as me you really should be using a standalone for the best results and safety.
Old Mar 25, 2006 | 07:11 AM
Jay'Z's Avatar
Jay'Z
ok.. thanks so im gonna make sure i truly understand the auto tune feature and get briefed on it by my tuner..
Old Mar 25, 2006 | 08:10 PM
Mark-SGP-'s Avatar
Mark-SGP-
Default Guy's we DO install and tune the UTECs, ---->>>>>
I have been traveling a ****Load tuning and have been very busy since being back..... I am getting ready to DRAG Jermy's( Inside JOKE )...Just Kidding Jermaine...LOL.... *** down here from TXS and get some other ideas I have up and going with the UTEC....I have been starting new MAPS from scratch for the turbo, big injector, built engines on the unit and did want to get started until I could get them in and done within a few hours of tuning. I am almost there soooooooo....Just give me a call if you have any questions but PLEASE remember....we have 56 cars in the Parking Lot.... NO, I am NOT joking....just ask the people that have been here lately!!!!...We are now 10 People strong and are still swamped....we are trying.... I should have time to start new customer & the UTEC tuning by the weeks end.....
Thank You for the space....
Mark-SGP-
2ndchanceZ
Oct 26, 2015 08:03 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
35reilly
Sep 28, 2015 07:42 AM
