Grounding Kit and Break-in period..
React3 : I suggest you don't punch a hole as per InsaneAmine's instructions (unless you want to) If you look at my pic, you can see that you can tuck it under the trim. I copied VQRacer's picture
WITH the hole.
Here is what I did. Used VERY thin philips screwdriver to punch through a round small hole. As I pushed the terminal into it, my son cut on the inside just enough to allow the terminal to go through. Result, the black rubber is tight against the red wire. Looks great.
