Skidazzle - How are the tiens working out?
Old Jan 28, 2003 | 07:31 PM
Alang's Avatar
Alang
Question Skidazzle - How are the tiens working out?
Have you had much time to really try them out?
Couple of quick questions.
1) Did you lower your car with the Tiens? If so, how much, and is there any problem with camber?
2) Is the EDFC unit a single DIN size? I was thinking that with a single DIN stero replacing the factory double din unit, the EDFC would look real nice in the extra spot. Think it would fit?
Also, do you have any pictures of the stepping motors installed?
thanks
Old Jan 29, 2003 | 03:16 AM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
1) yes, about 10mm
2) its 1/4 din
pics can be seen on the greddy car.
Old Jan 29, 2003 | 04:51 AM
MannishBoy's Avatar
MannishBoy
Can you describe the ride/handling in comparison with stock?
I assume the bounce can be tuned out.
Is the lowest setting about stock ride stiffness, or stiffer?
Thanks.
Old Jan 30, 2003 | 04:56 PM
TJZ's Avatar
TJZ
is it necessary to remove the front strut tower brace for the EDFC to work (b/c of space issues)?
Old Jan 30, 2003 | 05:59 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
full soft is slightly softer than stock.
full stiff is much stiffer than stock.
stock setting is about 3/16 clicks.
FSTB can stay in place for edfc to work.. the front mounts are inverted to hold the stepping motor inside.
m
Old Jan 30, 2003 | 09:38 PM
john350Z's Avatar
john350Z
hey skidazzle, i have my set with edfc shipping out tomorrow from tein.
they have had them for a while at the tein wearhouse, but there was an issue with the bracket for the right front strut housing, because at full clock, to the right i believe, would cause some rubbing issues to the brake lines.
you should call tein or audra at streetsports about the fix since you got one of the first sets.
anyway, are you satisfied with them, or would you go with jic or somethin' else?
how's camber issues?
let us know,
john350z
Old Jan 31, 2003 | 08:23 PM
Intrepid's Avatar
Intrepid
SKiDaZZLe, is the bounce gone?
Old Jan 31, 2003 | 09:25 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
yes this has been confirmed and posted by other members who have driven my car.
and john, that rubbing might be the stock brake line connector piece which bolts onto the knuckle... i dont have any of those pieces since i installed SS brake lines.... all i know is i have no rubbing issues...
m
Old Feb 1, 2003 | 09:18 AM
TJZ's Avatar
TJZ
Ditto. Did the lowering cause any camber problems?
Old Feb 1, 2003 | 09:52 AM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
no, no camber issues..
here is my take on this: (if i am wrong, someone please explain the correct scenario)...
the shocks have nothing to do with camber on the Z setup.
the camber angle is made by the length of each of the 2 control arms, and the angle at which the knuckle is held.
the shock connects the chassis to the lower arm. making this a smaller distance is not changing anything about the lower control arm's relation to the upper arm..
i think most people think lowering causes camber issues because they are used to macpherson setups on many cars. (in this case the length of the shock (and its angle) determine camber.
Old Feb 1, 2003 | 09:55 AM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
on second thought... working the diagram in my head... it might make a difference if you lowered the car sigificantly... my drop was only 10mm.
m
Old Feb 4, 2003 | 11:59 AM
N74DV's Avatar
N74DV
well here's my take.....
on suspensions with upper and lower control arms, typically the upper arm has a shorter distance from pivot point to steering knuckle pivot point than the lower arm.
the shorter distance on top will "pull" the top end of the spindle inward under substantial amount of suspension travel.
it's done that way because as you corner hard and the body rolls a bit of negative camber is introduced to keep the wheel from having positive camber in relation to the road.
I've never seen an upper and lower control arm suspension where the uppers are the same length as lowers.
If you lower the car significantly you'd see a bit of negative camber.... however, aftermarket companies should be offering adjustable upper arms soon cause by looking at the stock uppers, it seems real easy to have adjustable ones made....
hulkout
Tuning
Sep 30, 2015 12:33 PM
