Safe to rev the stock block VQ35DE to 7500 RPM
Is it safe to rev a stock block VQ35DE to 7500 rpm? Is there any durability issues I should be aware of? AFAIK, I have heard a few cases of the rod bolts stretching when the VQ is spun that high. Is there anyone doing this? I am currently waiting for a set of stiffer valve springs & retainers so I know my head & valvetrain can handle it. BTW I have a non-revup motor. Thanks.
Originally Posted by 97supratt
If its not revup I dont suggest doing that. I have the revup motor and I usually shift at 7200 so im quite sure it'll handle 7500.
What constitutes a "revup" motor? What is all involved with that mod? What is the stock rev limiter set at? What is the rev limiter set at with a "revup" motor? Sorry, Z-newbie here...
don't think you can do that unless you go for dual springs... and possibly you will bend your valves even with stronger valve springs. Also your rods might not be strong enough (at least rod bolts) to go that high and it might result in blown engine.. your power starts to drop off from 6200rpm already, there is not too much point for you to rev to 7500rpm though unless you put a set of cams in or use 2005 lower intake plenum to shift the max power up.
Check out my thread... accident happened from page 2, bent valves going 7500/7600rpm or so even with stronger nismo valve springs... and with ferrea valvetrain sets and pistons + rods, I am doing 8000rpm anytime any day now.
Good luck with your project!
https://my350z.com/forum/na-builds/159519-photos-on-engine-rebuild-n-a-2.html
cheers,
richie
cheers,
richie
Honestly I have raced and tried this as an experiment. I have shifted below redline around 6700, at redline 7000, and above redline 7200. Even though I dont have peak power at 7200, I shift at that rpm to have enough momentum and hit the "sweet spot" for the next gear. Thank you alberto for explaining what the "Revup" motor consisted of, made my job easier.
Originally Posted by Alberto
FWIW=-Mike @AAM revs to 7500rpm's on stock block/valvetrain on a regular motor. He also pushes 450+rwhp....
Reving a stock 03-04 VQ motor to 7500 rpms, is a bad idea IMHO. You can and will cause problems with the valve train as well as the stock rods...Besides, the power falls of after 6200 rpms anyway on the VQ...
Originally Posted by tonylittell
how are you shifting at 7200 when the rev limiter is set at 7000? that was the question
97supratt,
I might be wrong here, but I was told and heard many people saying that the revup motor's redline and rev limiter are the same which is 7000rpm... and the reson you can shift at higher rpm is most likely because the analog is not as accurate as the digital readings... so when you see 7200 or 7300 on the clock, most likely it is just around 7000rpm...
cheers,
richie
cheers,
richie
Originally Posted by Z350Lover
97supratt,
cheers,
richie
cheers,
richie
97supratt,
cheers,
richie
cheers,
richie
i know personally and for a fact that 7000rpm on a 03 motor is perfectly safe for abuse with no side effects. 7500rpm however, i am not sure i would try. theres is no power up there anyway unless you have cams?
Judging by the responses I'll keep the revlimit @ 7100-7200 (I'm not be spinning the VQ that high frequently......... well maybe if I have to get somewhere fast). I just installed the Nismo R-tune cams on my car and the motor want to rev beyond the 6600 rpm redline. One more question, will the 5AT be able to handle 7100-7200 WOT shifts w/o slipping? Thanks again!
