Quick Clutch Question
Old Mar 25, 2006 | 12:19 PM
infidsg35's Avatar
infidsg35
Default Quick Clutch Question
Hey I have a JUN Lightweight Flywheel. I looking to get a new clutch, but im a little worried about compatability. I was thinking of getting the Clutchmasters FX100. Will there be any problems with the between the 2?
Does anyone have any other clutch suggestions that will work with the JUN Flywheel?
I dont need anything crazy. Thanx!
Old Mar 26, 2006 | 07:11 PM
infidsg35's Avatar
infidsg35
BUMP Kinda need an answer this week thanx.
Old Mar 27, 2006 | 04:47 AM
johnlotusboy's Avatar
johnlotusboy
I am running the ACT clutch and the JUN flywheel and love the comb.
Th JUN flywheel is perfectly balanced out of the box.
JUN is also the only flywheel I would run, the aluminum ones are not SFI safety rated. They are likely to break off the crank after years of hard use.
If you want the motor smoother after install go to the Fluidamper front pulley.
Old Mar 27, 2006 | 06:39 AM
infidsg35's Avatar
infidsg35
Which ACT Clutch are you using? I was thinking of getting either ACT, JWT, or Clutchmasters.
I already have the JUN flywheel. But when I install it I want to replace the OEM clutch. But I want to make sure that the clutch I replace it with will have no problems with the JUN Flywheel.
Old Mar 27, 2006 | 08:14 AM
Noah@AAM's Avatar
Noah@AAM
i would recommend going with APS, or JWT with your flywheel....if you need a price or more help shoot me a pm.
Old Mar 27, 2006 | 08:47 AM
TTRANK's Avatar
TTRANK
I just did a poll on this. Most people are using the JWT and are very happy with it. I ordered the UR flywheel and am planning on the JWT clutch.
issyz
Jul 2, 2017 03:04 PM
kyin
Oct 15, 2015 05:54 AM
