3rd Engine, still burning oil... How long does it take to seat the rings.
Originally Posted by Netko350Z
Sharif is correct! My dad has a Porsche Boxster and hardly ever drives it hard. He maybe has only 1,800 miles on it and last summer he had to add 1 qt of Mobil 1.
So is it safe to assue that Mobil 1 oil sucks in that it will evaporate overtime?
Since I have started my oil consumptiontest I have driven 250 miles and not a single drop gone on the dealership oil. Could my problem been with the Mobil 1 oil?? Yet others hav had no problems at all with Mobil 1...
confused...
confused...
Many people I know that track/autoX/rally their cars and run Mobil 1 oil have noticed the same consumption phenomenon.
It might be worth the try to run a different oil. But personnaly, and assumming the oil consumption is from the "ring leak" I've described, I'm not worried. I'd prefere to have some oil leak into the combustion chamber from a surplus on the cylinder wall than the rings running dry.
Originally Posted by Gman2004
Not that you can properly read the oil with the chity dip stick we have anyway.
Originally Posted by King Tut
My first question would be are you 100% SURE you are reading the dipstick properly. Are you getting any oil on it?
Joel
^Scary!!!
I had the same amount of oil in my Z this last weekend when I changed it. Just a little over a quart of oil came out when I drained the engine. I'm not sure what happened but this last 5,000 mile period I burned through so much oil than I normally do. I should take my Z in to get inspected.
Originally Posted by Kolia
I'm guessing the engine will burn oil as long as you don't load the engine (accelerate WOT from 30mph in sixth gear) to set the rings
What exactly do you mean by this statement?
Why after 3 tries are they just replacing the short block? My engine blew due to oil consumption so of course the entire engine had to be replaced but I had no problems after that.. I even went FI on the second engine with no problems.
Originally Posted by zachcrosen
Long time no see man! Where you been for the past 3-4 months?
Literally under a rock, sold my car to get my business going and I've been working on that night and day. Now that a newer G35 is coming out I'm anxious to read the forums again.
Alot of it comes down to how the car was run-in.
if lightly, then the car will use alot more oil than one that was thrashed from new.
We have a New Beetle.. 1l per 600miles is acceptable according to VW/Audi.
All of you with oil consumption should try running amsoil synthetic. I run their 5w-40 euro synthetic and have no consumption. Also when i switched from dyno oil the car was noticeably more quiet during acceleration and much smoother on start-up. I love it
I had my shortblock replaced due to oil consumption that turned out to be a leaky 1-3 and 5 cylinder after a leakdown test. I was running mobil 1 synthetic and noticed it would burn off a lot faster than regular castrol 5w30 dino oil. I got my motor replaced and went back to regular castrol. I have not burned any oil since the motor replacement. You should NOT be burning any more than 1 qt per 3k miles IMO or something is wrong. New motor or not, I didnt burn off any oil when i got my motor replaced. If I got my motor replaced 3 times I would lemon law the car in a second. I was very close to doing it when I had my motor replaced once, but I thought I would give it a chance and so far its been a great motor. If it goes bad again though I am going to lemon law the car.
Goodluck.
Goodluck.
I took my car to jiffy lube where they told me I should go with 5W-30 synthetic. They could not have been more wrong. With the Z you should use at the very least 10W-30 non-synthetic; I am now using 20W-50 because my engine went through 6 quarts of oil in 330 miles and has developed compression problems. The point is don't use synthetic.
Synthetic is not the cause of your high oil consumption. Take that car to the dealer for a warranty engine swap.
Well, thats only part of the story. Another problem caused the loss of compression. The light weight synthetic oil only made the matter worse. I don't think I can take my car to the dealer for warranty work because of the mods I've done (headers, dual exhaust, high-flow cats, plenum, CAI, Unichip ECU, clutch, flywheel). I'm taking it up to Scott Performance tomarrow.
