06.. wont reset ecu
Old Apr 1, 2006 | 10:07 AM
rob142sti's Avatar
rob142sti
Default 06.. wont reset ecu
i tried resetting the ecu via TS instructions... it doesnt work for some reason.. at times the SES light will blink like its suppose to, then stop when its suppose to keep blinking..
i know its not me because my friend has an 04 and i reset his without any problems...
could the 06 ecu be different to reset?
Old Apr 1, 2006 | 01:55 PM
Wholey Smokes's Avatar
Wholey Smokes
I was under the impression that you couldn't use the Technosquare reflash with the 06s because of the timing on the exhaust cams.
Old Apr 1, 2006 | 03:08 PM
Blue_Z's Avatar
Blue_Z
make sure you do it exactly as it says. you'll need a stopwatch.
I've done it plenty of times on my 06 when my loaner ECU wasn't fully recognizedy by my car so it would go into "limp mode" every 35 miles.
Here's my summary of the reset instructions from TS's page
1. Turn the key to ACC, start stopwatch
2. At 00:03 seconds press the accel pedal in and out 5 times and stop just before you reach 00:08
3. Do nothing until 00:16, at 00:16 press the accel pedal down.
4. Let go of pedal at 00:26
5. Press again at 00:36
(Check engine light should start blinking from a slow blink to a fast blink by now)
6. Let go at 00:46
7. Press again at 00:56
8. Let go at 01:06
9. Turn off car
10. Restart Car, CEL should be gone
Like I said, I would have to do this every 35 miles and although it was a nusiance, I learned how to do this in my sleep.
You won't have this problem when you go to TS, it only went into limp mode because I was the first 06 they tested on so they had to give me an 05's 35th anniv ECU. I was the guinea pig.
Anyways, TS Reflashes on 06's are possible and they'll be ready for all 06's sometime soon. Although I can't say when.
Old Apr 1, 2006 | 08:18 PM
Nexx's Avatar
Nexx
why not just disconnect the negative on the battery overnight?
Old Apr 1, 2006 | 09:41 PM
99atlantic's Avatar
99atlantic
disconnect the battery for 24hrs; the pedal method does **** compared to pulling the power (as said in the service manual)
Old Apr 2, 2006 | 07:32 AM
Juanito350Z's Avatar
Juanito350Z
So can I reset my ecu like that then.. but it will only work for 35 miles..?
Old Apr 2, 2006 | 09:42 AM
99atlantic's Avatar
99atlantic
no, on a a/t the computer will gradually learn your driving habbits and start granny shifting if you arn't flooring it 24/7 (i *think* this can be avoided by using manumatic mode al the time though)....on a/t or m/t if you have mods it will eventually start to lean itself out over time and you'll need to reset again after a few months..........it's kinda like s2000s - they gradually pull timing from the stock until they're reset.
Computer's running cars these days......
Old Apr 2, 2006 | 11:08 AM
HarvesterUT's Avatar
HarvesterUT
sometimes i dont like to have to reset all my radio station presets on my HU :P
Old Apr 2, 2006 | 11:15 PM
Juanito350Z
Talking
6. Let go at 00:46
8. Let go at 01:06
9. Turn off car
OK Bro.. I did exactly like the instructions read cuz I have that CEL on. It worked it went away but my question now is what did it exactly do...? How long will this last, am I going to be able to use the full potential of my mods..?
Old Apr 2, 2006 | 11:27 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
wait.. the ECU will go back to stock mode over time even after resetting it?
Old Apr 2, 2006 | 11:28 PM
3hree5ive0ero
Retired Admin
also.. should i be resetting the ECU after each performance mod?
Old Apr 3, 2006 | 04:37 AM
pingrr's Avatar
pingrr
I have never had any luck with the pedal method. I just unplug the negative terminal on my batery every other on Thursday night. Luckily for me my radio retains all of the info that was preset into it.
Old Apr 3, 2006 | 08:52 PM
Fa1rLadyZ's Avatar
Fa1rLadyZ
ditto
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
