Heater broke after radiator flush
Old Apr 17, 2006 | 12:28 PM
Rppngears's Avatar
Rppngears
Default Heater broke after radiator flush
I was doing the 30k mile maintenance last weekend. Everything went fine except the radiator flush. Well, at the time it seemed to go fine, but now I notice my heat is not nearly as hot as before. Can anyone explain this? I opened the heater air release valve as stated in the shop manual when filling it. I've driven the car and then checked the fluid level 6 or 7 times now. It moved down ever so slightly, <1/2 cup, a few times. Any idea what could cause this?
Old Apr 20, 2006 | 07:07 AM
RAR's Avatar
RAR
There is an air bubble in one of the hoses going to the heater core. Same thing happened to me when I removed the upper water pipe to install my headers. There is an air bleeder hole on the heater hose back by the battery, have you tried opening that to let air escape?
Andrew
Old Apr 20, 2006 | 08:56 AM
350Zteve's Avatar
350Zteve
Yep, its an air bubble. Here's the solution I found that works very well. On the firewall, towards the passenger side of the engine, you will see a heater hose with a plastic fitting in it. This is the air bleed. Once your car is COMPLETELY cool, remove the plug with a large phillips head screwdriver. Place a rag under the hose to catch any drips. Using a very small funnel, slowly pour in some 50/50 coolant until it won't take any more.
After you close up the air bleed, drive the car as normal. You may have to repeat this cycle a few times. When I replaced my radiator, I had to do this step 4 times before I got good heat. Each time, the car would take a few more ounces of coolant in the back. Once the air is all out, your heater will be just fine.
Old Apr 20, 2006 | 09:26 AM
first350's Avatar
first350
After you close up the air bleed, drive the car as normal. You man have to repeat this cycle a few times. When I replaced my radiator, I had to do this step 4 times before I got good heat. Each time, the car would take a few more ounces of coolant in the back. Once the air is all out, your heater will be just fine.
+1
Chris350z03
Oct 8, 2023 07:19 PM
SonnyWu
Nov 24, 2015 08:19 PM
SharX59
Sep 30, 2015 10:54 AM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
SharX59
Sep 27, 2015 09:23 AM
