Pro-Torque Torque Convertor First Impression
Old May 3, 2006 | 08:56 PM
dscheers's Avatar
dscheers
Default Pro-Torque Torque Convertor First Impression
Just got my car back from installing the Pro-Torque TC. Took it for a sopin. My mechanic is a drag race driver and tried the car out too. This is a write up of our combined first impression.
Technically: the Stall Speed has been raised to about 3200rpm and the Torque Multiplication has been upped to 2.5x (from 1.7x if I remember correctly). The internals are bulletproof; the brazed fins must be as close to unbreakable as possible. The anti-balooning cover looks and feels solid.
Impressions: I find it kind of a strange feeling... Somehow the cars feels slower below 3000rpm. Mechanic says that's an easy to get impression but completely false. It's because once the car hits 3000rpm, it feels like shot out of a slingshot.
Rev it to 3Krpm with the foor on the brake. Let go. Weird! The car "crawls" like 5 feet, then jumps ahead with more power then ever. This will improve any launch hugely. I clocked 60ft times improved by 0.4-0.5 sec with my (calibrated) Gtech.
Daily driving is improved too. Although the car feels slower below 3000rpms, the torque available at the lower end is much higher than before. Getting going is way smoother., Driving up the parking ramp is all of a sudden a lot "easier". Where before my tires would spin, the tires now hook and propell the car up in an almost scary way (maybe that's because there was a car coming down ).
For 600$, this is one great mod for a 5AT. Pro-Torque offers a core exchange for 400$. Note that the core is HEAVY!
Thanks for reading
Danny
Old May 3, 2006 | 09:47 PM
Fairlady_z33's Avatar
Fairlady_z33
Nice I heard it was good from another member in the forum. I was going to get it but then was thinking on going manual well all my thoughts on the tranny are put to a stop due to the fact that I just got an awesome deal on a Fcon full set up. Well good to hear now enjoy it and go to the track to see your times.
Old May 3, 2006 | 10:32 PM
dscheers's Avatar
dscheers
BTW: this is the same as the SGP TC
Old May 4, 2006 | 05:25 AM
JoneZZZ's Avatar
JoneZZZ
Good read....thanks.
I thought it interesting that Torque Multiplication was increased.....did they tell you how this was done....changing the vanes maybe?
Old May 4, 2006 | 06:14 AM
blackend's Avatar
blackend
nice write
Old May 4, 2006 | 06:35 AM
roneski's Avatar
roneski
Any difference in the way it feels when it shifts? How does full auto mode run compared to before?
Old May 4, 2006 | 06:42 AM
blackend's Avatar
blackend
nice write
Old May 8, 2006 | 09:28 PM
dscheers's Avatar
dscheers
Default How to change Torque Multiplication
Because of its blade design, the stator shown on the left provides a harder launch (more torque multiplication) than the stator on the right.
Old May 8, 2006 | 09:29 PM
dscheers's Avatar
dscheers
I don't think ir changes anything to the way it shifts, that would be more of a job for the ValveBody...
Danny
Old May 8, 2006 | 09:32 PM
dscheers's Avatar
dscheers
Fin angle also plays a big role in a torque converter’s stall speed. The two different fin angles (shown) demonstrate part of what’s inside a converter to change stall speed. Note: these are not the stators.
Old May 8, 2006 | 09:38 PM
dscheers's Avatar
dscheers
New impressions: Have my street tires mounted again. It's definitely easier to chirp the tires off the line.
Old May 14, 2006 | 06:26 AM
CESAROTORRES's Avatar
CESAROTORRES
What make you think that?
Thx
Ceasr
Old May 14, 2006 | 04:53 PM
dscheers's Avatar
dscheers
Thx
Ceasr
Look a bit closer at the SGP offering:
SGP Racing / Pro-Torque Converters for the NISSAN 350Z / G35 5AT's. This is simply the best converter we have ever tried. This upgrade with the VB upgrade we offer will COMPLETELY ELIMINATE turbo lag on a 5AT!!!! Even on a factory car we reccomend upgrading the TC to one of our units...You will be amazed at the performance increase you will gain from this simple upgrade... We have VERY FEW cores but, do have some. That means a short turnaround time to get your unit in your hands & on the car...Here are just some of the special features found in this unit...:
Old May 14, 2006 | 07:59 PM
CESAROTORRES
Got it! THX!!!
Do you think it is better that the EDGE TC?
Thx!
Cesar
Old May 14, 2006 | 08:13 PM
dscheers's Avatar
dscheers
Got it! THX!!!
Thx!
Cesar
Wouldn't know, haven't tried any car with that one. But there's another company apart from SGP that uses Pro-Torque; so I guessed PT must be ok... And can't complain !
Danny
Old May 15, 2006 | 04:42 AM
CESAROTORRES
Danny
Thx bro!
I will call PT today for more info.
Cesar
USA FL
5AT (APS TT)
Old May 15, 2006 | 12:10 PM
overZealous1's Avatar
overZealous1
the torque mutiplication happens by raising the stall speed, which is a direct effect of vain angles and converter size. the vains work to compress the hydralic fluid (trans fluid) to act as a solid. the higher the stall speed, the more torque and hp you will have at that point. higher stall converters allow slippage at the areas below the converter lock up though, and create more heat. trans cooler should always be used with higher stall converters, heat KILLS autos.
Old May 15, 2006 | 12:15 PM
dscheers's Avatar
dscheers
Check the pictures above. Together with this excellent explication, they should give you a very good ideaa what is done to make the changes happen.
Danny
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
James1990
Dec 16, 2015 08:57 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
carid
Misc.
Sep 10, 2015 06:16 AM
