harness removal
Hey i have a problem I have gotten all of my harness plugs out accept 2 hat wont budge there the ones in the back of each head
here is a pic of te passenger side.
Its the green harness plug.
driver side
driver side
looks like the camshaft postition sensor
http://www.g35frenzy.com/downloads/2...anual/B/ec.pdf
pages 264-271
pages 264-271
There is a push tab on it. Push it in with your finger, and then you can remove the connector.
FYI, I assume you are removing your engine. In which case, from my experience, its way easier to just unplug your ECU, and pull the harness up through the firewall and rest it on your engine. It takes about 5 mins to do this, rather than fighting every connector off your engine.
yea i tried pushing the tab in but didnt work. I ended up just un bolting it. also even if i did take the hrness from the ecu idk why but the Z harness upper and lower are not joined by a conector its just one large harness.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
