What Size Gauges Fit In Stock Gauge Location?
Old May 16, 2006 | 09:15 PM
Sundeviljay's Avatar
Sundeviljay
Default What Size Gauges Fit In Stock Gauge Location?
i want to put my gauges for the vortech where the stock gauges are on the dash of the z. what size gauges fit in there? anyone know?
Old May 16, 2006 | 09:34 PM
Sundeviljay
bump
Old May 16, 2006 | 10:16 PM
Sundeviljay
nobody knows? i don't have a 350z or else i could measure it...
Old May 17, 2006 | 03:25 AM
zachcrosen's Avatar
zachcrosen
I believe both 52mm and 60mm gauges will fit. I have seen several people with the Defi BF Series gauges in there and I think they are all 60mm.
Old May 17, 2006 | 03:35 AM
gringott's Avatar
gringott
52mm is too small.
Old May 17, 2006 | 05:46 AM
sq40's Avatar
sq40
Anyone have a how to for taking that apart? Does any company make a gauge that will match the Factory ones?
Old May 17, 2006 | 07:47 AM
gringott's Avatar
gringott
If you search the forum you will find something, ppl have put Defi gauges in particular in there. Basically, you remove the center console fall, the "gauges" are mounted on a circuit board, they are all attached to each other, so you would strip it down until you just had the hood and the bottom scoop out, then you would have to fit the new gauges in the openings using self made mounts of some kind. I think quite a few have used hot glue to fix it in there. I have one completely taken apart here, I think some creative plastic work will fit those gauges in there.
Old May 17, 2006 | 07:55 AM
Sundeviljay
if i get 52mm gauges i could just make something to get them to fit in there right?
Old May 17, 2006 | 10:03 AM
zachcrosen's Avatar
zachcrosen
Originally Posted by gringott
52mm is too small.
I thought there was a guy on here running the Defi D gauges (52mm) in the stock locations?? Maybe I was wrong.
Old May 17, 2006 | 10:38 AM
gringott's Avatar
gringott
Ok, I just took the black plastic part that fits behind the silver rings. That part fills the circle opening - it is the full diameter. It measures 60MM. What I have seen people do is remove the silver ring, and fit the 60mm gauge in the opening. To make it fit 52 mm you would have to make a bezel or something that covered that gap. I fit a 2 1/16 gauge into the hood just for a look and the silver bezel on the gauge was inside the silver bezel of the hood. So I think it would be hard to make it look right. 60MM will work however.
DarkCreep
Oct 17, 2015 11:50 PM
Calinismo350z
Sep 14, 2015 04:04 PM
