PLS Help ! My car is Sick
Old May 22, 2006 | 01:46 PM
kim's Avatar
kim
Default PLS Help ! My car is Sick
Now I can't Rev. More then 2,500 rpm
No air leak , No vacuum leak ???
and I get this from OBD - Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
Do I have to replace MAF sensor ?????
Old May 22, 2006 | 02:20 PM
undrgnd's Avatar
undrgnd
In a word, yes. Is that the only CEL? Did you accidentally pinch any wiring recently? Is the MAF connector on fully?
Old May 22, 2006 | 02:31 PM
03BlkSETE's Avatar
03BlkSETE
Not being able to rev past 2500 rpm is a almost a sure sign the MAF needs replacing.
Old May 22, 2006 | 10:32 PM
kim's Avatar
kim
Yes I did???
I try to get RPM signal from ECU
Local Nissan qoute me $609 for MAF sensor
What is the PIN Number of RPM Signal ???
Old May 22, 2006 | 10:36 PM
kim's Avatar
kim
It's like Fuel cut off
Old May 23, 2006 | 03:34 PM
peptidbond's Avatar
peptidbond
How did you try to get the RPM signal? Did you try to tap a wire? If so, you might have just done a poor tap and ended up cutting the wire. I would check the wire. If it is cut, you MIGHT just be able to solder it back together.
I guess we need more info.
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
