Behold . . . Head from a 350Z!
Old Feb 13, 2003 | 02:45 PM
gfornal's Avatar
gfornal
VQRacer the pathfinder, altima and maxima use the same motor. The same block and heads, The intake is different.
thanks,
Greg
Old Feb 13, 2003 | 03:11 PM
menehune's Avatar
menehune
I jealous. Did you really took those off a Z or another V35?
Old Feb 13, 2003 | 03:24 PM
MannishBoy's Avatar
MannishBoy
That's his Z, I'd bet. I saw it partially disassembled last week
Old Feb 13, 2003 | 04:49 PM
MardiGrasMax's Avatar
MardiGrasMax
I have a set in my garage that is being packed up to sent to Altimat from the Altima board.
If you want pics of the block, rods, pistons, crank, let me know.
The intake ports are large, but the exhaust ports are the same size as the VQ30, so some enlargeing their would help, especiially for boost and juice applications. The compustion chamber is 51.5cc much larger than a VQ30. Notice the dimples in the walls of the intake port for good swirl/tumble. Some bowl work and light cleaning up is all they really need. Coating of the valves for heat rejection would also help.
I have sent the rods and pistons off as samples to have custom parts made for mass pruduction via a well known Nissan performance shop, it should be a few months before thay are ready.
Would their be any intrest in copper head gaskets?
Old Feb 13, 2003 | 05:14 PM
iris's Avatar
iris
I just want to say, I thought this subject matter of the thread meant something altogether different (i.e., dirty). LOL! should have figured it wasn't from the forum it was in, i guess.
Old Feb 13, 2003 | 05:16 PM
Andorion's Avatar
Andorion
Default LOL
That was my first thought too Guess my mind's just corrupt!
~Berj
Old Feb 13, 2003 | 07:19 PM
VandyZ's Avatar
VandyZ
We share the wealth:
http://350zmotoring.com/forums/showt...0582#post10582
Old Feb 13, 2003 | 07:48 PM
MannishBoy's Avatar
MannishBoy
I hear there is an excellent welder around town to help Doug if he needs it
Old Feb 13, 2003 | 07:54 PM
Finality's Avatar
Finality
Isn't the engine mounted differently as well? I believe its at a 90 degree mount to lower the COG.
Old Feb 13, 2003 | 11:03 PM
Mr B's Avatar
Mr B
Does Nissan use variable valve timing on all the VQ35DE engines?
Old Feb 14, 2003 | 04:43 AM
VandyZ's Avatar
VandyZ
sorry new link:
http://350zmotoring.com/forums/showt...&threadid=1202
Old Feb 14, 2003 | 04:45 AM
VandyZ's Avatar
VandyZ
When I posted this under dougs account, he said to make the title catchy . . . so I did! He wants points!
Old Feb 14, 2003 | 05:21 AM
MardiGrasMax
Maxima, Altima, 350Z, G35 for sure all have it.
Old Feb 14, 2003 | 06:50 AM
ACEMAN's Avatar
ACEMAN
Master
Default So your testing the Car tomorrow
with the new headers. Cant wait to see the HP#'s. Over the 300Hp mark would be great with the headers. Keep us posted
This is what i love about this forum, people are always trying to better there car and like to share it with others.
Keep the info coming
Later
Aceman
Old Feb 14, 2003 | 06:28 PM
dougrace zs's Avatar
dougrace zs
Well, if you had really checked the exhaust ports they are quite a bit larger then the VQ30 and I had to do alot of grinding on the flanges that were made for the VQ30 to make the headers fit.
As far as bowl work, have you had these heads on a flow bench to confirm your suspensions ? We have, as for the combustion chamber volume you have to make it bigger because there is more bore and stroke that will lower compession ratio. duh!!!!!!
Old Feb 15, 2003 | 05:47 AM
VandyZ's Avatar
VandyZ
"OWNED"
Old Feb 16, 2003 | 04:41 AM
  #38
MardiGrasMax
I really did check them and they are the same size. Do you have VQ30 heads to compare too, I do? Perhaps your flanges are crap?
My coment about the bowls was more directed at the fact that the ports are clean and dont appear to need much work from a DIY perspective. Flow bench, yea sure, i got one next to the valve seat grinder in my basement.
Gosh you are a genius with the cc theory, arent you.
I'm not trying to steal your thunder here doogy, so no need to scent mark your thread.
Old Feb 16, 2003 | 07:12 AM
  #39
dwnshift's Avatar
dwnshift
We ran the B&B(version 2 or three) headers last month at Daytona. It was 20 degrees warmer than in January test and we went faster on the banking.
Old Feb 16, 2003 | 08:09 AM
  #40
Emax02's Avatar
Emax02
"OWNED"
