Biggest Off the Shelf cams avail?
Old Jun 6, 2006 | 12:57 AM
Spanners's Avatar
Spanners
Default Biggest Off the Shelf cams avail?
Anyone know the biggest off the shelf cams avail (both duration and lift)
Yes I'm lazy, but also very busy
Old Jun 6, 2006 | 09:39 AM
97supratt's Avatar
97supratt
Nooooooooooooooooooooooob
Old Jun 6, 2006 | 10:06 AM
rx7/350z's Avatar
rx7/350z
the popcharger cams are the best
Old Jun 6, 2006 | 10:18 AM
Acree's Avatar
Acree
+1
-Acree
Old Jun 6, 2006 | 11:17 AM
UnderPressure's Avatar
UnderPressure
NISMO has cam blanks available.
If you spend the $$ to run the RZZ heads you can run the S2 NISMO cams.
FI use, Tomei 268.
This is your 1 time get out of Noob free card. The search function is your friend.
Old Jun 6, 2006 | 12:41 PM
rx7/350z's Avatar
rx7/350z
wtf? noob free card? when did we start giving out these
Old Jun 6, 2006 | 12:43 PM
doug's Avatar
doug
i just bought some.. but i am too lazy to look up the duration and lift
Old Jun 6, 2006 | 02:12 PM
Spanners's Avatar
Spanners
Noob? I've just had a look at some of your posts on this forum.. pot.. meet kettle..
I'll admit, I've done little VQ work, but before you start calling someone a noob, you should maybe have some idea of what they actually do for a living.
268 are no where near big enough.
Nismo blanks AFAIK are too small for what we need - am in contact to see if they have anythign special laying around.
Looking at 290 11.5-13mm lift (without having to custom build them)
Old Jun 6, 2006 | 02:43 PM
97supratt's Avatar
97supratt
Your still a noob!
Old Jun 6, 2006 | 02:45 PM
done12many2's Avatar
done12many2
Wow! There is a huge window between 11.5 and 13 mm lift.
What exactly are you trying to do?
Old Jun 6, 2006 | 02:50 PM
Spanners's Avatar
Spanners
97supratt - You're still a **** -I spent 2 hrs looking last nite.. I'm sure its out there somewhere.....
done12many2 - Lol.. I realise that... looking for all options in the range.. though I doubt we'll find anything in the top region, hence why I asked.
What are we tring to do?? Sub 7's @ 200+
Old Jun 6, 2006 | 02:54 PM
dougrace zs's Avatar
dougrace zs
We have 292 11 mm lift intake cams if your interested they will work with stock valve springs and heads call me 615-327-4159
Old Jun 6, 2006 | 03:02 PM
ken350z's Avatar
ken350z
Doug, what cams do you use in your car?
K
Old Jun 6, 2006 | 03:03 PM
Nathan's Avatar
Nathan
Nismo have 2 different 1/2 processed cam blanks available
1st Part# 1300F-RRVQL Work angle up to 284, Lift up to 11mm
2nd Part # 1300F-RRVQH Work angle up to 312, Lift up to 14mm
Old Jun 6, 2006 | 03:16 PM
Spanners's Avatar
Spanners
Good to talk to you Doug
WOW! thats what I'm talkign about.. hopefully Nismo will come back with availability on them. Cheers
Old Jun 6, 2006 | 03:18 PM
97supratt's Avatar
97supratt
Noob
Old Jun 6, 2006 | 03:20 PM
dougrace zs
The cams I am running currently running are 292 11mm lift intake and 265 11 mm lift exhaust
Old Jun 6, 2006 | 03:21 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
no off the shelf cam is going to get you where you want to be spec wise, but you can come close
you canot use anywhere near a 13mm lift without new pistons, springs, valves, etc etc etc.
The NISMO Type B Blanks can be ground to a max of 312 degrees of duration and .551 " lift. These are blanks that you would then need to have ground to spec.
I don't see how 11.0mm of lift would work with stock springs...you cannot even use stock springs on Tomei 268's (stock springs do not have enough travel)...but that's a different topic . The max a NISMO spring can travel is what a Tomei 268 has lift wise. I know this because we originally were going to use the NISMO springs with the NISMO Spec 2 cams on Kwame's car, and now will be going to Supertech duals.
Further, if this is a forced induction car, you are not going to need to worry as much about duration as lift.
Old Jun 6, 2006 | 03:33 PM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Doug did you happen to get my email? I've been really busy lately and havent came around to call. Im the one asking about the intake,plenum, and strut.
