FYI, HKS DLI II - worth every penny NA!
Originally Posted by Sharif@Forged
The UTEC doesnt have 2 step...yet...but hopefully soon
Hopefully someone will do a before and after dyno run on the HKS DLI. I would like to see the results.
The map switch has the clutch pedal sensor connector part on it already.
Nissan recommends 100K mile, but NA I melted a grounding strap to the elctrode in a cylinder of course causing a nasty misfire. Long story shot I swapped to 50K and the plugs looked like DEATH! Car felt much better with the new plugs. Id say 40-50K miles swap em, for the money and the easy install its a small price to pay for keeping the engine running strong.
I concur, my plugs were white. BTW $499 was the price at Z1, not including shipping, which was like $15.
Originally Posted by William@Altered
You don't need a harness - it's plug and play
They are on backorder for 2 months at Hopup, BTW, the unit comes with the harness for the 350Z.
Originally Posted by Black_Sunshine
$499 at www.hopupracing.com as well.
this all sounds very interesting
i never knew this part existed or that our engines were direct injection
what gapped plugs are on the market to match with this HKS unit, or do you have to gap the plugs yourslef?
Originally Posted by drifter23
Anyone know what the difference this product is versus the Sun Hyper Force System...? Or are they the same?
Sun Hyper Force System: http://www.sigmaautomotive.com/HFS/hfs.php
I gapped my plugs at .045. Again, my undersatnding is the the Sun system helps with getting lost volts to the plugs whereas the HKS system magnifies the signal to the plugs. And I gapped the new Iridiums myself.
William...you're not the only ones that has them
The harness is necessary - you cannot install it without it.
I'll be doing a before/after dyno on my car in the coming weeks, so stay tuned. I have a DLI II sitting here waiting to be installed
thanks...I'll give THEM a call.
