Jwt Tb
Old Jun 11, 2006 | 06:05 AM
supra crazy's Avatar
supra crazy
Default Jwt Tb
Hey i JustInstalled my JWT Trow out bearing on my car while the engine was out. The people who installed mt JWT flywheel and clutch just used the stock one. and didnt install the one that came with the kit. But now after installing the new one, when I hit the clutch it goes almost to the floor then starts feeling normal when it is almost down. and it Says down you leterally have to pull it back up and it will spring back into place. Is the caused because i need to bleed my clutch line or is it something else?
Old Jun 11, 2006 | 08:06 AM
supra crazy
bump
Old Jun 11, 2006 | 09:29 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
they did not bleed it at all from the sounds of it
Old Jun 11, 2006 | 03:25 PM
done12many2's Avatar
done12many2
This is not a big deal at all. They just need to bleed it again.
Old Jun 11, 2006 | 07:56 PM
supra crazy
yuo sure?
is there any adjustment i need to mess with JWT bearing seems bigger then stock bigger as in thinckness. but it was recesed. also is ther any adjustment for the clutch pedal? because it is extreamly hard to get into gear when the enging is on. it seems as if the clutch isnt disengaugeing
Old Jun 12, 2006 | 05:26 AM
supra crazy
I figured it out. There is some sort of engaugement bolt that needed to be adjusted under the clutch pedal.
thanks though
B Esquire
Sep 24, 2015 07:52 AM
