Convert a 05 287 engine to a rev up?
Old Jun 13, 2006 | 04:31 AM
ken350z's Avatar
ken350z
Default Convert a 05 287 engine to a rev up?
Any way to convert a 287 engine to a rev-up? Is it worth while? What's required, just the exhaust side cam timing mechanism and a ECU tweak?
Old Jun 13, 2006 | 04:46 AM
playa6tnine's Avatar
playa6tnine
in the end, its not worth it for the money and time spent.
Old Jun 13, 2006 | 05:20 AM
ken350z's Avatar
ken350z
What does it cost to it? Did you look into it?
Old Jun 13, 2006 | 06:13 AM
captj3's Avatar
captj3
It's most likly not worth it. At a minimum you would have to change the heads, timing chain, and most important the ecu. The old ecu won't run variable exhaust timing for the valves.
Old Jun 13, 2006 | 06:25 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Its NOT WORTH IT, top end sucks just as bad past 6200rpm's on a Revup over a standard engine so imo the redline is worthless and the TQ is down. At the end of the day stock for stock its a drivers race-why anybody would invest $$$ on that is beyond me.
Old Jun 13, 2006 | 06:33 AM
undrgnd's Avatar
undrgnd
There is more to it than just variable exhaust valve timing. A trip to the Nissan website will answer all your questions. The higher redline was attained through micro-polished journals and other 'invisible' refinements, so have a ball.
Old Jun 13, 2006 | 06:57 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
I posted up all the parts in a thread...
the main difference is the lower intake manifold (shorter runners, less low end power, more high end power), stronger connecting rods, exhaust cam timing...
if you want to get the exhaust cam timing to work, you will need a new front cover, cylinder heads, for the rev up cylinder heads to work you will then need to change the pistons.... basicly, too much work...
best thing to do will be to just get the rev up intake manifold, and you will make more HP up to around 7500 RPM....
here is the original thread I did when the rev-up motor came out...
https://my350z.com/forum/showthread....&highlight=rev
Old Jun 13, 2006 | 07:50 AM
97supratt's Avatar
97supratt
Not when they are boosted though, Sharif has tested it and the REVUP motor made around 30whp more than the 287.
Old Jun 13, 2006 | 10:02 AM
ken350z's Avatar
ken350z
Yeah, sounds like it isn't worth it. I like the low end torque anyway.
Old Jun 13, 2006 | 10:07 AM
Hmmm...I'm not sure how to give up 10 pounds of torque?
Old Jun 13, 2006 | 10:23 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Not that I dont trust Sharif-but every tune is different, every car is different even with the same set-up. If he had that experience good I believe it, but when I start seeing more boosted Revups consistently putting down around 30whp more than other setups Ill believe it, its too early imo to tell...
Old Jun 13, 2006 | 12:46 PM
97supratt's Avatar
97supratt
I remember him saying, same setup, same boost, etc. It could be the exhaust cam timing or it could not.
Old Jun 15, 2006 | 01:34 AM
Jason@Performance
Performance Nissan
look for 350zlover i believe is the screen name...
he did a build up of a 287 motor with the rev up lower plenum...
Old Jun 17, 2006 | 06:03 AM
ALong's Avatar
ALong
Our SCCA T2 racecars are actually 2004/2006 hybrids now. We run the cams out of the 2006 Rev-Up along with the 2006 lower plenum, ARP rod bolts and stiffer valve springs. Technosquare has a specific ECU program for these mods. We are redlining the motor at 7800rpm with no problem.
Old Jun 17, 2006 | 11:33 AM
Jason@Performance
Performance Nissan
yup!
gotta machine the exhaust cams a little bit if any of you with the 287 want to put on the OE cams..
They arent that expensive either...
Old Jun 17, 2006 | 01:13 PM
ALong's Avatar
ALong
Actually you dont have to machine the cams, found that all you need is a longer cam bolt which you have to source from a fastener supplier.
Old Jun 17, 2006 | 03:01 PM
Jason@Performance
Performance Nissan
good to know!
I know at first they were machining..
thanks!
Old Jun 17, 2006 | 03:50 PM
ALong's Avatar
ALong
No, nissan comp told us that they thought we might need to do some minor machining, but after someone actually installed the Rev cams in a 2004 motor it was found that that was not true. The cams drop right in, only problem is the exhaust cam needs a longer bolt and the 2004 bolt is not long enough. Otherwise a complete bolt in.
Old Jun 17, 2006 | 05:02 PM
Nano's Avatar
Nano
how much are the revup cams?
what are the specs compared to the stock 287hp cams?
Old Jun 17, 2006 | 05:14 PM
Jason@Performance
Performance Nissan
dont know the exact spec's...
as far as price, ill have to check from the office... but if i remember correctly... the set of four is under 1000... IF i remember correctly..
