Eibach Pro-Kit
Old Feb 18, 2003 | 10:04 AM
REDZSTER's Avatar
REDZSTER
Default Eibach Pro-Kit
Hello,
I am interested in buying a Pro-Kit Suspension kit for my 350 track. I bought a kit like this for a 02' SpecV Sentra and it worked out fine, but I did not investigate them any. Now that I am putting them on a more expensive car, I want to know about the effects, harmful or not, that they might cause. Also, do I need to buy anything else along with the prokit? or can I just put them on and everything will be ok. The drop is .8 in front and 1.2 rear. Thanks
Adam
Old Feb 18, 2003 | 02:46 PM
dwnshift's Avatar
dwnshift
Adam,
You might want to hold off on any lowering kit for the Z. When you lower the Z , you gain negative camber. Too much negative camber is not good ecsp when you gain more neg under compression.
We will be soon releasing our adjustable upper control arms so you can adjust the camber on the front, and adjustable rear camber arms.
stay tuned..........
Bodyboarder81
Nov 2, 2015 12:17 AM
seagrasser
Oct 11, 2015 03:27 PM
