line lock question?
Old Jul 11, 2006 | 03:24 PM
eltness350's Avatar
eltness350
The Untouchable
Default line lock question?
Does anyone have one installed? I went to order one and summit said it might not work because of the ABS.. Does that sound right to you? I just cant seem to do a good burnout...
Old Jul 11, 2006 | 03:59 PM
Bullitproof's Avatar
Bullitproof
I'm in the same boat. i was told because of the abs it would be a pain to fit. I would love to have a line lock on the g-wagon.
Old Jul 11, 2006 | 06:13 PM
Z ELIMINATOR's Avatar
Z ELIMINATOR
Default line lock
i installed it on my 03. you need two soliniods. They have to be installed on the front brake lines. One soliniod per line. Good luck with the fittings has I had to have 4 custom hose and fitting made for it 450.00 CDN. I used hurst soliniods. Works well. Do not do burnouts on street tires. Waste of tire's. I have weld rims and slicks on the Z.
it is very hard to mount everthing in the brake compartment but i did took me 6 hours including wiring.
Lots of fun and a lot less flesh on the fingers and arms. It a quicker installation if some body helps you.
Good luck.
Old Jul 11, 2006 | 06:18 PM
Gary King's Avatar
Gary King
I met a guy not to long ago who had an awesome line-lock setup on his Z. He had a switch that selected horn or line lock in his cabin, the horn or the line-lock could be used by pressing his horn depending on where the switch was set. It was very slick.
Old Jul 11, 2006 | 06:26 PM
eltness350's Avatar
eltness350
The Untouchable
thanks guys
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Mattg350z
Oct 2, 2015 06:51 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
Tochigi_236
Sep 27, 2015 03:40 PM
