UR Pulley question..
Old Jul 20, 2006 | 01:57 AM
dingobiatch's Avatar
dingobiatch
Default UR Pulley question..
I'm thinking about getting a UR pulley (I have a popcharger, hks td exhaust, and putting on mrev+, 5/16 spacer, and HFC's - is a UR pulley a good next move?), and I wanted to make sure of something. This is the pulley that is popular, correct?
Old Jul 20, 2006 | 04:49 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I have the UR underdrive crank pulley and like it. Don't think it give great gains but, I feel it smoothed out my powerband. I don't feel anyone needs the kit. I say go for it!
Old Jul 20, 2006 | 05:47 AM
first350's Avatar
first350
I have the UR under-drive set - love it! But next time I wouldn't get the set...the crank pulley is all you need. (The other pullies cost more $, don't reduce weight that much, and the Alt pulley is harder to install than the crank!)
-Peter
Old Jul 20, 2006 | 06:48 AM
slickwilly23's Avatar
slickwilly23
I have the set and love it as well. It's true you really only need the crank pulley, but if your in there anyways you might as well change em all and just do it all the way.
Old Jul 20, 2006 | 09:12 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
Only really need the crank pulley as mentioned above... the other 2 pulleys (Power steering pump / Alternator) are both same size and weight as OE...
We have seen up to 8rwhp across the full RPM range with the crank pulley, you will get better engine response as well...
On a turbo car you see even more gains then this...
http://mynismo.com/products/?id=4366
Old Jul 20, 2006 | 09:23 AM
correct
Old Jul 20, 2006 | 09:53 AM
Nano's Avatar
Nano
the engine response is totally worth it...
Old Jul 20, 2006 | 06:57 PM
dingobiatch
Umm.. a little worried. Sent an email to CalienteAutomotive.com about buying some stuff, one of the things I mentioned was the UR crank pulley.
This was part of his response:
"On the crank pulley I will warn you now, we have had several customers replace their crank pulley with an aftermarket and within weeks experience extreme wabbling of the pulley (I don’t know if that is a word) which ruins the crank seal. In one extreme case a customer had to replace the crank because the key that fits in the crank had so much play it etched out the notch where the key sits. Once that happened the crank was garbage and it cost him $3000 to get back up and running. Long story short I would think long and hard about replacing the crank pulley because the gains are definitely not worth the risk."
Is this true?
Old Jul 20, 2006 | 07:14 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I've heard of this happening but I, and serveral others, haven't had any problems. It is your call. My question is the installation on the one that had problems.
Old Jul 20, 2006 | 11:37 PM
Cannysage's Avatar
Cannysage
I should've could've might've gotten the whole set, instead of just the crank. your pulleys are purty heavy, especially the crank. I felt a good pull with it I really like it. test pipes and pulleys are my favorite.
Old Jul 20, 2006 | 11:48 PM
dingobiatch
Hmmm.. but he says that the problem happened to a few different people, and also this thing about this guy having to spend $3000 in repairs..
Scary. How long has everyone had theirs?
Old Jul 21, 2006 | 12:33 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I installed mine in Jan/Feb this year.
Old Jul 21, 2006 | 05:20 AM
Jason@Performance
Performance Nissan
this is not a honda motor...
our crank is internally ballanced without a flywheel or a crank pulley on it...
the factory crank pulley is cast iron which has potential to be more unballanced then the UR pulley's...
Then again, you cant say anything good about a product when the install is done poorly...
I had a UR pulley on my car for 55000 miles and no problems...
our race cars run them... no problems...
Old Jul 21, 2006 | 06:01 AM
first350's Avatar
first350
If you install the crank pulley, just make sure to read the instructions...when you tighten the new crank pulley back on, you go to XX ft-lbs, then you turn it another XXX degrees of rotation. (Sorry, I forget the exact #'s) I wonder how many ppl mess up or forget the 2nd part...if it's not tightened properly, it'd make sense that in a relativley short amount of time it woud start to get loose.
IMO, if it was a problem with the design of the pulley (vibrations, quality...) problems would show up after more than a few weeks. If you're getting failures within a few weeks of the install, my bet is always on the installer (there's always a chance that it was a bad part, but overwhelmingly it's the installer)
Old Jul 21, 2006 | 06:15 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I could almost bet that ppl don't retighten after 500 miles.
Old Jul 21, 2006 | 06:19 AM
Nano's Avatar
Nano
Is this true?
That happens because someone is too stupid to read the manual and get the proper torque specs. (it happened to a friend of mine when he removed the stock pulley and did not torque it back properly).
I have had the pulley for 15K miles with no issues.
Old Jul 21, 2006 | 06:36 AM
mikead_99's Avatar
mikead_99
Yes and no. Apparently for a while the UR instructions only included the part about tightening to xx ft/lbs, and didn't mention the additional 60 degree turn. Yes people could have avoided problems by looking at the factory service manual for the correct tq spec, but I know I probably would have just followed the instructions that came with the part. I think UR definitely had their share of the responsibility for the related failures, but I can also tell you that their instructions are corrected now.
Old Jul 21, 2006 | 06:37 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
From what I remember from reading on here, it's 30 ft-lb, then 36 ft-lb, then you tighten it 60° more.
Old Jul 21, 2006 | 07:15 AM
g_torphins's Avatar
g_torphins
Bit of a horror story emerging on the 350ZUKOC site:
http://forums.350zukownersclub.com/i...=0&#entry56964
NissanGB techs say UR pulley was to blame
Old Jul 21, 2006 | 07:19 AM
EM-EFER's Avatar
EM-EFER
I have some for sale.. PM me a offer... they are Silver and come with nessecary hardware.
