do i need to reset my ECU?/
Old Jul 31, 2006 | 04:02 PM
DaytonaBlu350Z's Avatar
DaytonaBlu350Z
Question do i need to reset my ECU?/
Can someone tell me really quick if i need to reset the ECU if i just put in the JWT pop charger in? i know this is probably been already covered but i need an answer asap. I found how to do it with the brake pedal. is that the right way to do it. also if i reset the ecu will i need to do anything else beside resetting the radio stations and clock? thanks in advance
Old Jul 31, 2006 | 04:08 PM
bailey bill's Avatar
bailey bill
If your intake actually changes the airflow rate, the AFM will give that data to the ECU.
bill
Old Jul 31, 2006 | 04:15 PM
Swiffer's Avatar
Swiffer
No, you do not need to reset it.
If you do reset it, the only things that will change are the stations/clock and maybe the homelink settings (not sure on that)
Old Jul 31, 2006 | 04:34 PM
Gators2001's Avatar
Gators2001
Homelink stays.
Reseting wont hurt, but it might not help either.
Its a personal Call.
Old Jul 31, 2006 | 05:08 PM
Ztalker's Avatar
Ztalker
ecu will reset itself in a few days of driving around. The same with underdrive pulley install.
Old Jul 31, 2006 | 05:11 PM
How is the car running? OK? Leave the ECU alone.
Old Jul 31, 2006 | 07:56 PM
DaytonaBlu350Z
the car runs great. the rpms are around 500 when in neutral. is that normal??
Old Aug 1, 2006 | 07:48 AM
Kiamo's Avatar
Kiamo
IIRC the target is 650 with +/- 250 RPM leeway.
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
