Difference in temperature on Dyno
Old Aug 13, 2006 | 06:50 PM
vpannu's Avatar
vpannu
Cool Difference in temperature on Dyno
Hey everyone,
I recently got some more toys put on my 04' 6mt g35 coupe but unfortunately the numbers weren't that great.
In January this was the setup:
Mods: strupp Headers, kinetix y-pipe, crawford v5 plenum, jwt intake w/ z tube. Stock exhaust.
1/17/06, 57 degrees, Humidity at 42%, SAE 0.94
Power= 248.61 Torque=240.55
Last week the dyno was done with all the above mods in addition to Crawford High Flow Cats, Crank Pulley, Unichip
8/10/06, 80 degrees, Humidity at 43%, SAE 0.99
Power=246.49 Torque=232.58
I was hoping to reach high 250's with these mods or barely gettin over 260 rwhp. If I can get some advice as to what the problem may be. Is temperature a big factor in the loss of HP and Torque? Or does anyone have a setup similar to this or knows where the problem lies in my set up where the car isn't getting its peak performance? Thanks for the tips!
Old Aug 13, 2006 | 07:15 PM
HighwaySpeed's Avatar
HighwaySpeed
Lightbulb
Cool, dry air is the best for engine performance.
Old Aug 13, 2006 | 07:20 PM
gtmule's Avatar
gtmule
Well, the correction factor should take care of the ambient temp difference. Other variables vcould be oil temp, oil weight, water temp, fuel, blah blah. Chassis dynos are pretty unrelaible. Typically on an engine dyno you can control all these variables (including ambient air condtions) to within a couple percent, this is just baout impossible on a chassis dyno. so, you may have gained power, you prolly did, but mabye had a higher water temp or.....?
Also look at the area under the curve, not just the peak #'s, see what that tells you.
Old Aug 13, 2006 | 09:08 PM
Agree. The numbers are corrected. On the first dyno you were docked 6 percent (SAE correction 0.94). On the second dyno 1 percent.
Old Aug 14, 2006 | 05:32 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Silly Q, but is your Unichip tuned? If so how much, street tuned? Just A/F tuned? Timing also?
Old Aug 14, 2006 | 07:23 AM
mikead_99's Avatar
mikead_99
From just a glance the correction is a little off. SAE standard is determined at 29.23 hg, air temperature 77 degrees F and humidity at 0% so a run at 80 and 43% humidity should have an additive factor, not a decrease.
Old Aug 14, 2006 | 11:25 AM
Q45tech's Avatar
Q45tech
6 months between runs? obviously you were running winter blend vs summer blend gasoline.
Useless to compare dyno runs unless the fuel came from same batch! Often there can be a 5% or more variance in BTU and Ried Vapor pressure.
Was one [summer] ethanolized and the winter not?
Old Aug 14, 2006 | 09:27 PM
roast's Avatar
roast
Since barometric pressure wasn't listed(temp and humidity alone mean nothing).... looking at weather records for his area, and using a SAE correction calculator, the correction factor was spot on. Higher baro. pressure + colder temps + less humidity = docked a higher percentage.
The second run had higher baro pressure than the standard 29.23(it was 29.9), which is why the air was still more dense than the standard, even with more humidity and a slighter higher temp.
Old Aug 15, 2006 | 03:44 AM
mikead_99's Avatar
mikead_99
From just a glance .....
lol, thanks roast. I knew I shoulda done more than glance at the numbers before posting my last.
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
