Anyone Install the HKS Hipermax LS coilovers?
Old Mar 1, 2003 | 11:45 PM
Intrepid's Avatar
Intrepid
Default Anyone Install the HKS Hipermax LS coilovers?
If so, how is the ride compared to stock?
Thanks.
Old Mar 2, 2003 | 06:01 PM
3kgto's Avatar
3kgto
Hi,
I have HKS Hipermax LS installed on my car and had it lowered 3/4". The ride quality is not harsh, it rides just slightly firmer compared to stock. Most importantly it eliminates the bounce we face on the stock setup.
Hope this helps
Rgds
3kgto->FairladyZ
Old Mar 2, 2003 | 06:05 PM
Moroccan_Mole's Avatar
Moroccan_Mole
i also have them coming to me, ill post some pics/reviews when i get them installed. should be next week sometime.
Old Mar 2, 2003 | 06:11 PM
fdao's Avatar
fdao
Originally posted by 3kgto
Hi,
Hope this helps
Rgds
3kgto->FairladyZ
That is fantastic to hear! How does it corner?
Old Mar 2, 2003 | 06:13 PM
fdao's Avatar
fdao
Looking forward to it.
Old Mar 2, 2003 | 06:50 PM
Intrepid's Avatar
Intrepid
Thanks for the review. I understand the height is adjustable. Can you set it to NOT lower the Z? Thanks.
Hi,
Hope this helps
Rgds
3kgto->FairladyZ
Old Mar 2, 2003 | 08:30 PM
Moodie's Avatar
Moodie
Minivan Racer
Default How many clicks (dampening) for the front and rear?
Just want to get an idea what dampening people use. Thanks!
Old Mar 3, 2003 | 03:29 PM
Intrepid's Avatar
Intrepid
Only the ride height adjustability according to HKS.
Old Mar 4, 2003 | 12:12 AM
3kgto's Avatar
3kgto
Hi all,
The Hipermax LS is only height adjustable (HKS recommended height setting is rather close to stock) and the dampening can't be adjusted.
The car gives greater confidence during cornering, however, I can still feel a very slight bodyroll during a fast sweeping corner. But the kit makes up for itself by not being too harsh during normal cruising. But your car will still "jump" abit if you run over a raised bump on the road too fast.
I think I'll try to summarise my own opinioned pros and cons of the kit to answer more questions you guys may have.
Selling point:
- Double layered front upper pillowball mount (this removes those irritating clonking noise that you would normally hear on single layered pillowball mount system)
- Height Adjustability
- Provides a firm but none to harsh ride (good for occasional racer type of driver)
Cons:
- No dampening adjustability restricts fine tuning (more serious trackie may prefer to go with JIC or Tein Coilovers)
- No camber adjustment kit available yet to complement the system. (I'm running approximately -2.5 degrees rear camber with a drop in 3/4" height on the street. It is going to eat up my tyres real fast. I'm waiting for some company to release a camber adjustment kit for the rear before dropping lower)
Hope this helps further!
3kgto->FairladyZ
Sunset Orange JDM Zed
-Stock Smoked Front Reflector, front under bumper spoiler
-HKS Hipermax LS
-Work VSXX Chrome Rims Front 8.5x18, Rear 9.6x18 (3.25" lip)
-Michelin Pilot Sports tyres Front 245/40-18, Rear 275/40-18
Old Mar 4, 2003 | 09:40 AM
Intrepid's Avatar
Intrepid
3kgto,
How is the RIDE compared to stock?
Is the "BOUNCE" corrected?
Thanks!
Old Mar 4, 2003 | 01:46 PM
fdao's Avatar
fdao
Originally posted by Intrepid
3kgto,
Thanks!
Yes it does, according to 3kgto. Look at his first post at the top.
Old Mar 4, 2003 | 05:09 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
Hi,
Hope this helps
Rgds
3kgto->FairladyZ
not sure If I understand it, it get rid of the "bounces" but it's firmer? is this possible? I thought if it's firmer, then it would still bounce? maybe someone can explain a little? I am new at this suspension thing.. Thanks!
Old Mar 4, 2003 | 05:28 PM
Intrepid's Avatar
Intrepid
Yes, a little more detail would be great as I'm considering these coil-overs. I'm interested in eliminating the bounce, not lowering the Z and keeping about the same ride firmness.
Old Mar 4, 2003 | 06:09 PM
3kgto's Avatar
3kgto
Smile
- Yupe it does remove the bounce and you can maintain the original height. As for the firmness, I think the LS is the closest to stock when compared to other kits offered (or none others I can think of at this point in time)
Old Mar 4, 2003 | 06:21 PM
Intrepid's Avatar
Intrepid
Thanks.
