Greddy Informeter?
Old Sep 5, 2006 | 07:30 AM
josesantigo57's Avatar
josesantigo57
Default Greddy Informeter?
Has anyone tried out the Greddy Informeter, its looks like a very sweet gadget that reads alot of parameters...
Communicates with the factory ECU to read up to 25 Channels Like: Speedometer, RPM, Water Temp, Ignition Timing, Injector Rate, Intake Air Temp, Fuel Temp, Air Flow Voltage, Intake Manifold Press, 02 Sensor Voltage, A/F, Battery Voltage, Throttle Position, WGV, ATF Temp, EGR Temp, Gear Position, 4WD Ratio, Exhaust Temp.
Or so they say, anyone tried it or seen it? Thanks.
Im tempted myself...
Old Sep 5, 2006 | 09:17 AM
Quamen's Avatar
Quamen
I have read a number of write ups on it and it looks like an awesome gauge. I have been tempted to get one but I am also tempted to know if it works with our ECU.
Old Sep 5, 2006 | 09:18 AM
Quamen's Avatar
Quamen
I wonder if it can be recalibrated for A/F ratio or if it goes out of calibration after 1000 miles like the AEM supposedly does.
Old Sep 5, 2006 | 09:21 AM
THE TECH's Avatar
THE TECH
I have it. Works well. It will not do anything a/f related except read the stock sensor.
Old Sep 5, 2006 | 09:22 AM
Quamen's Avatar
Quamen
Dumb question because I know I have seen it before but what is ratio range on the stock 02 sensors?
Old Sep 5, 2006 | 09:24 AM
mcderns's Avatar
mcderns
I just got it last week. Its a neat little toy. I mainly wanted it for coolant temps, the rest is just a bonus.
Old Sep 5, 2006 | 12:14 PM
josesantigo57
So the only reading we dont get is A/F Ratio, everything else work alright?
Could we see were you guys have these mounted?
Old Sep 5, 2006 | 12:47 PM
Minda's Avatar
Minda
Does it need wideband sensors?
Old Sep 5, 2006 | 04:01 PM
dTor's Avatar
dTor
No, because it is not a WBO2 controller, and it does not read WBO2 signals. You need a WBO2 system, separately, to read WBO2 info. There is no cheap way to read WBO2. You've got to suck it up and fork over the dough if you want WBO2.
Old Sep 5, 2006 | 05:41 PM
Quamen's Avatar
Quamen
Does it work with the speedometer and tach?
Old Sep 5, 2006 | 05:46 PM
mcderns's Avatar
mcderns
Yup. On the sixfold monitor I have mph, tach, coolant temp, intake temp, batt voltage, and ignition timing shown.
Old Sep 5, 2006 | 06:31 PM
Quamen's Avatar
Quamen
Wow!
So basically the A/F is the only thing that does not work with this unit?
Old Sep 5, 2006 | 06:37 PM
Quamen's Avatar
Quamen
Does this measure air temperature (manifold)?
Old Sep 5, 2006 | 07:01 PM
i8acobra's Avatar
i8acobra
Yes.
Old Sep 6, 2006 | 09:09 AM
Quamen's Avatar
Quamen
That is awesome! I will be getting one very soon as the Air temperature could be extremely useful for some of the research I am looking to do regarding heat in the intake tract!
sales@czp
Sep 23, 2019 03:30 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
