Weird clutch problem you might not have heard of.. HELP!
on
I have this buzzing noise when the clutch is pressed in but only when it is in gear. I can feel the buzzing through the clutch pedal when this happens. It starts at around 2500 rpms and stops at around 4500 rpms. This noise and virbration cannot be heard or felt when the clutch is not pressed in. I do have JWT clutch and flywheel but it started happening today. However, I adjusted the clutch today and lowered it a little bit. Anyhow, it still happens after adjusting it back to where it was... Also, the clutch is not slipping at all BTW and I only have about 1500 miles on the clutch. Please help if you guys know what might cause this, thanks!
08-06-2021 06:19 AM
