If anyone hasn't changed the differential fluid yet...
Old Sep 13, 2006 | 04:27 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by Ed 718
exactly how difficult was this install can we accomplish this with average mechanical skills............can you help a rican out
Ed you have the LSD right? Not base model? (I'm not sure if it makes a difference)
I'll talk to you later about what kind of tools you have and we'll work something out. Worst case scenario you can bring it to my apartment in west LA and we'll do it here...
You can take some initiative and buy 2 quarts of the Redline 75W-90 plus 4 quarts of MT-90 (if that's what you want to use) here
http://store.summitracing.com/egnsea...362+115+400236
And get 4 of these washers
part number 110264n200
from performance nissan oem site
http://www.trademotion.com/partlocat...?siteid=214252
Old Sep 13, 2006 | 04:43 PM
Quijano187's Avatar
Quijano187
im getting this done asap .. thanks for the info wired 24 7
Old Sep 13, 2006 | 04:45 PM
zz350zz's Avatar
zz350zz
Does the dealership change the diff fluid at the 30,000 mile maintainance?
I got the maintainance done but that was 16,000 miles ago.....and if they didn't change it then, its never been changed
Old Sep 13, 2006 | 04:56 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
You'll have to ask the dealer if it's included in the normal 30k service. Each dealer is different.
Old Sep 13, 2006 | 05:00 PM
Fear's Track 06's Avatar
Fear's Track 06
how often should the oil in tranny and diff. be changed?
Old Sep 13, 2006 | 06:44 PM
genxnympho's Avatar
genxnympho
Hey Wired I see you did not do the MTL/MT-90 mix in the tranny as some do. Perhaps it is a little thin for for some but is there reason why some suggest to mix the two?
Old Sep 13, 2006 | 07:37 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
No idea.
Old Sep 13, 2006 | 07:52 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I would think after putting in synthetic fluid etc., it should last at least 60k miles...
Otherwise if you're going to do it at the dealer I'd say maybe 30k
Old Sep 14, 2006 | 04:56 AM
Armitage's Avatar
Armitage
Was your rear diff. clicking before this? Did this stop that?
Old Sep 14, 2006 | 05:25 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
rear diff clicking has nothing to do with fluid - it has to do with retorquing the axle bolts
Old Sep 14, 2006 | 06:54 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
Mike they fluids all say trans and gear oils so which one is ideal for the diff and which one for the trans......
Old Sep 14, 2006 | 08:05 AM
charlie_rdstr_Z's Avatar
charlie_rdstr_Z
I'm getting a crunch on 5th gear now so hopefully when I change fluids it will go away
There are different parts list such as one says 2 crusher washers while another thread says 4. Can someone verify what exactly is needed?
4 jackstands
rags
pump
diff fluid how many?
tranny fluid how many?
crusher washers how many?
Old Sep 14, 2006 | 08:20 AM
savvy's Avatar
savvy
does it make any difference that i have a base model?
Old Sep 14, 2006 | 08:29 AM
charlie_rdstr_Z
You won't have an LSD unless it's aftermarket.
Old Sep 14, 2006 | 10:14 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
MT-90 will work for the trans (4 quarts)
and 75W-90 "Gear Oil" for limited slip diff (2 quarts) will work for you.
If you have the base model without limited slip differential, you might want to check out "75W-90 NS" ... Not sure though. It's probably best to ask someone from redline or wherever you're buying your oil. http://www.redlineoil.com
As mentioned in THIS THREAD: https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/131098-changing-the-differential-transmission-oil.html
allen wrench 10mm or hex wrench 10mm
floor jack
4 jackstands
rags
drain pan
fluid transfer pump or suction gun
diff fluid 2 quarts
tranny fluid 4 quarts
crush washers
You need at least 2 to replace the drain plug washers, but it's safer to buy 4 so you can replace the fill plug washers as well. Most people say "they looked fine" but the reality is you can't un-crush metal.
Old Sep 14, 2006 | 02:43 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
The diff doesn't click, as mentioned, it is the axles that click. Yes I had the axle clicking. Performance Nissan fixed it for free (TSB).
Update... I really feel like the synchros work better than before.
I always rev-match on downshifts but sometimes you just don't give it enough "blip" and the synchros have to take over. Well the synchros definitely feel a bit smoother than before with MT-90
Old Sep 14, 2006 | 03:10 PM
97supratt's Avatar
97supratt
I bought 6 quarts of 75W90. I used 4 for the trans and 2 for the diff. The trans was clean, the diff was dirty. The outcome was simple, much smoother acceleration and shifting.
Old Sep 15, 2006 | 04:41 AM
  #38
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Not the best tool ever, but it got the job done. It was nice that I didn't have to be under the car while pumping.
http://store.summitracing.com/partde...5&autoview=sku
About the heavy shockproof: I don't know if I would use it in my trans. Simply because I can't seem to find whether it's GL-5 or GL-4 rated.
Redline states that the heavy shockproof gear oil is not safe for synchromesh transmissions because it breaks down snychros. I personally have it in my rear diff and MT90 in the trans. I do know a few people that have used the heavy shockproof in their transmissions without any ill effects.
Old Sep 15, 2006 | 05:18 AM
  #39
350Zenophile's Avatar
350Zenophile
Thumbs up
Thanks for the reminder Wired...ordering my stuff now.
Does anyone have any experience with Specialty Formulation MTL-P? Someone mentioned it in another thread and it looks promising since it's the exact weight specified by Nissan and I do a lot of in-town, short trips where the tranny really never gets to a good operating temperature:
Originally Posted by Specialty Formulations
It is designed as a replacement for Honda MTL HG (part number 08798-9016), Nissan/Infiniti HQ Multi 75w85 (part number 999MP-MTF00P), BMW MTF-LT-2 (part number 23 00 7 533 514), and some Audi fluids. It is specifically recommended for applications requiring a 75w85 lubricant and works well in manual transmissions and transaxles that experience problems with low temperature shifting.
Old Sep 17, 2006 | 09:50 AM
  #40
corsair's Avatar
corsair
I changed out both the tranny and diff fluids at 10K miles. I did the changes independently of one another and noticed a difference immediately in both the tranny and the diff after changing the fluids. I went with Royal Purple in both and have been very happy.
Attached Thumbnails If anyone hasn't changed the differential fluid yet...-rp.jpg
