gaining more power of a stock Z
Old Sep 17, 2006 | 06:26 PM
locodave's Avatar
locodave
Default gaining more power of a stock Z
Hey guys,
Besides turbo charging the Z, are there any mods you can do to increase the power of a stock Z?
Cams, re-map the ECU, exhaust, manifold?
Just curious to see what you can get done and what gains you get.
Thanks
Old Sep 17, 2006 | 06:33 PM
HDPDZO6's Avatar
HDPDZO6
Prepare to be flamed...
iceman21_23's Avatar
iceman21_23
search...
Old Sep 17, 2006 | 06:44 PM
Zincognito's Avatar
Zincognito
i hope you joined to use the search button!!
Old Sep 17, 2006 | 06:55 PM
locodave's Avatar
locodave
I did use it! And what i gathered was there is hardly any gains unless u turbo charge it. But I was hoping someone has gained some significant power without turbo charging it!
Old Sep 17, 2006 | 06:56 PM
Todd350ZX's Avatar
Todd350ZX
NOS would be the cheapest route. Probably about half the cost of FI.
Old Sep 17, 2006 | 07:16 PM
locodave's Avatar
locodave
JWT Pop Charger - Is that just an air filter?
I should say im in Australia and it's illegal to use NOS
Old Sep 17, 2006 | 07:46 PM
Zincognito's Avatar
Zincognito
I think its illegal anywhere but the track. A popcharger is a filter and NA is by far the most costly for minimum gains.
Old Sep 17, 2006 | 07:48 PM
efx's Avatar
efx
Exclamation
classic!!!! you were 2nd post too, i like your style
Old Sep 17, 2006 | 07:57 PM
Ztalker's Avatar
Ztalker
Hey guys,
Thanks
i heard test pipes/y-pipes/pop charger/plenum spacer/underdrive pulley will be your best bet for NA and they are mostly DIY...good luck mate.
Old Sep 17, 2006 | 08:03 PM
Brick-Z's Avatar
Brick-Z
As with any vehicle, mods will increase torque and hp. There are many useful tools to find your answer. Intake, exhaust, spacer, HFC, larger plenums, NOS all increase hp. All depends on how much hp you want and how much you want to spend.
Old Sep 17, 2006 | 08:13 PM
FastZ33's Avatar
FastZ33
im not the type to flame so imma help u out. do a complete bolt on.......headers, tp, exh, pulley, mrev,intake, ecu
Old Sep 17, 2006 | 08:29 PM
Voboy's Avatar
Voboy
new wheels and you will be set
Old Sep 17, 2006 | 08:58 PM
rAiN's Avatar
rAiN
more money spend more power you get.
Old Sep 17, 2006 | 09:56 PM
Varis air duck.
Old Sep 17, 2006 | 10:57 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Hey guys,
Thanks
If you look around you will find some dyno printouts from people who have installed mods, and how much power they made.
Old Sep 18, 2006 | 12:21 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
If you're serious into creating an NA monster, look into the stroker kits. I believe they run the car at 4.3 liters. Be prepared to be spending more than FI for this route though.
Old Sep 18, 2006 | 05:23 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
The majority of available NA gains can be made with:
1) plenum spacer and/or MREV2
2) test pipes
3) exhaust
4) UTEC
After that you can get headers and cams but it gets real co$tly.
There is also a 3.9 final drive to give a good kick.
Old Sep 18, 2006 | 05:53 PM
Nismo 350z's Avatar
Nismo 350z
The most bang for ur buck mods NA you can do is pop charger, spacer/MREV2, test pipes, y-pipe and a crank pulley.
Old Sep 18, 2006 | 06:01 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
anda computer to make it run as it should ^
