6000 miles, droped a valve.
Old Sep 28, 2006 | 01:58 PM
BluZee's Avatar
BluZee
Originally Posted by rocks
Update - finally talked to the head guy in the tech department. Nissan requires them to tear down the old motor first to see what failed and if its cheaper to fix it. Should know in a few days what failed inside. He said i should be getting a new engine.
I work at the Nissan dealership in Midland. We had an Armada do the same thing and Nissan had us tear it down also. We only replaced the head.
Old Sep 28, 2006 | 02:33 PM
rocks's Avatar
rocks
What exactly happend on the armada? If it was valve wich im sure its probably embedded in the piston...
Old Sep 28, 2006 | 02:58 PM
BluZee's Avatar
BluZee
My bad, it actually dropped two valve seats, not a valve.
Old Sep 28, 2006 | 03:06 PM
Eazzy's Avatar
Eazzy
Prob the same cylinder though ???? Or not ???
OOPs just caught that ---Seats---Thats sometimes Overheating/
Old Sep 28, 2006 | 07:10 PM
BluZee's Avatar
BluZee
This Armada that Im talking about had just come in from the factory on a transport. So basically it had no miles on it.
Old Sep 30, 2006 | 12:51 AM
thumpboarder's Avatar
thumpboarder
Originally Posted by LIdrew
If I have to add oil between changes, there is a problem. That oil BETTER be full or there is a consumption issue. I personally plan on taking my car to the dealer with low oil to show them "look, you guys did my oil change 4k miles ago and it's half gone already. I do understand the point you're trying to make however about not giving them anything to blame you for.
<---3 quarts low on first change. Next change I was 1.5 quarts low after 2700 miles. Using Mobil 1 5w-30 as the manual recommends just without the Mobil 1 part. btw, I change my oil every 3,000 miles regardless of what I use!!!! Its going in after my next 1500 miles for its consumption test.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
