? ..::Ground clearance::.. ?
Old Mar 11, 2003 | 07:52 PM
dangerzone1280's Avatar
dangerzone1280
Question ? ..::Ground clearance::.. ?
What's the ground clearance for the Touring Z with 18"s? Have problems with speedbumps? or ramps/driveways?
Old Mar 11, 2003 | 07:59 PM
ares's Avatar
ares
Veteran
4.7" speedbumps have NEVER been a problem but if their big, take em slow, I think the 4.7" point is between the tires so its hard to bottom that out. but still go slow.
as for driveways, it has a short nose and even shorter and taller tail, so it doesnt scrape too often, but if you pull up to a curb or parking bump thing that WILL scrape. also sharp inclines particularly at a somehwat higher speed will scrape.
basicly the car will be fine for all bumps and angles as long as you take the big ones slow. and dont pull too close to curbs, youll get the hang of that.
