how to swap pumpkins
Old Oct 18, 2006 | 07:18 PM
mykel's Avatar
mykel
Default how to swap pumpkins
So seeing as how I have a base Z, I got a used VLSD pumpkin from a higher model (from Jim from Turbo Toys BTW, who was really nice and gave me a great deal!)...anyways, I was wondering what was necessary 2 swap out the pumpkins, how easy it is, how long it might take and...where the pumpkin infact, is.
I have NO idea where it is, and no mechanical experience at all. Yes, I can jack a car, install a JWT Popcharger but, those are pretty self explanatory and one had instructions. HELP!
Old Oct 18, 2006 | 07:21 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
dont do this yourself!!! Its worth the 200 for someone else to do it!
BUT IF YOU MUST
It isnt hard but if you have no experiance at all it would be somewhat challanging.
its in the rear of the car, at the end of the driveshaft... unbolt the 4 bolts from that, the axles, take the clips for the speed sensors off carefully, the breather tube for, and the I think there is two nut n bolt combos to take off... takes about 2 hours~
Old Oct 18, 2006 | 07:27 PM
mykel's Avatar
mykel
Okay, I may have lied just a little. I know basically how to do the small things on a car. That doesn't sound TOO bad. Plus, I'm going to my friend's garage to get my car lifted to work on it.
Plus my friends going to help me, and he's done a good amount of work on cars, seeing how he worked at a gas station garage for a good summer. His uncle whose dealed with trannys for 20 years is also going to be there so, they'll know a lot. But just incase, I wanted some instructions.
Old Oct 18, 2006 | 07:42 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
Just watch out for the speed sensors dont crush them otherwise itll f up the ABS and youll be out a nice chunk of change!
Old Oct 18, 2006 | 08:28 PM
meatbag's Avatar
meatbag
Be careful its a heavy motha.
Be sure to have a torque wrench too so you can get all the bolts tight evenly.
SpartanZ32
Oct 22, 2015 09:36 AM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
SharX59
Sep 27, 2015 09:23 AM
