03 Z possible problem
Old Oct 23, 2006 | 07:14 PM
RedDevil03's Avatar
RedDevil03
Default 03 Z possible problem
I just got an 03 Touring the car is stock with 27,000 miles and i have a question. when the car is at idle there is a weird noise that sounds like something is spinning really hard, you can feel alot of vibration in the stick. then when i press the clutch pedal it stops, but when i let go it starts up again. another thing is when i shift into any gear it feels like i have to kinda force it in there. when i drive in between shifts it sounds like a blowoff valve or pressure is being released (the sound is coming from the gear lever) . does anyone know if this can be a potential problem? thanks
Old Oct 23, 2006 | 08:35 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
The noise you hear coming from the transmission is normal when you're in neutral. We have very noisy transmissions.
If you have trouble shifting I recommend you use swap the transmission and differential fluids for some Redline fluids.
Check out the links here:
https://my350z.com/forum/engine-drivetrain-and-forced-induction-diy/131098-changing-the-differential-transmission-oil.html
https://my350z.com/forum/engine-and-drivetrain/216785-if-anyone-hasn-t-changed-the-differential-fluid-yet.html
Also you should read up on the top 100 questions thread, link in my signature. It will likely answer many of your questions, please check it out before starting anymore threads...
welcome to the forums and enjoy your Z
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
