differential question
Old Nov 1, 2006 | 10:51 AM
ofl0926's Avatar
ofl0926
Default differential question
hey whats up guys. i have an 04 base model Z. i wanted to know if i can just replace my lsd and put an oem vlsd or after market vlsd. will there be anything extra that i would need to do? i use to have a 240sx and we use to be able to just to bolt it up and it worked fine. does it work the same with the z33. thanks guys
Old Nov 1, 2006 | 10:54 AM
sq40's Avatar
sq40
You have no LSD on a base. If i am not mistaken, there are aftermarket LDS's available though.
Best bet is to buy a whole Pumpkin with the gearing and VLSD you want in it and bolt it up.
Old Nov 1, 2006 | 10:55 AM
Motormouth's Avatar
Motormouth
you can sway the complete pumpkin, but some years have different size flanges I think it was.
if you were building WITH your non Vlsd pumpkin you can get a drop in Quaife unit, or any of the others you need stub axles (and some other things). The nismo unit comes with the extra stuff you need to install.
I saw Z-1 selling a conversion package for the Cusco RS unit for a base pumpkin.
Old Nov 1, 2006 | 11:11 AM
ofl0926's Avatar
ofl0926
so its just best to replace the whole pumpkin
Old Nov 1, 2006 | 11:17 AM
njsho's Avatar
njsho
It depends, if you want a quaife, then you should stick with your current setup. Decide if you want a stock VLSD diff, or aftermarket. If you go aftermarket decide on you diff, then change your pumpkin according to what is needed to work with the diff.
Old Nov 1, 2006 | 11:41 AM
Motormouth's Avatar
Motormouth
and if you are FI, now might be a good time to switch to the auto final drive.
or if you are staying NA, break it open and do the 3.9 gears if you want.
Old Nov 1, 2006 | 12:53 PM
ofl0926's Avatar
ofl0926
yea i want to stick with an oem vlsd. what in the world is a quaife??? also where can i get an auto final drive or 3.9 gears...
usually when you do this type of work, how much do parts usually come out for. i am new to the 350z so i am still learning
Old Nov 1, 2006 | 01:39 PM
Motormouth's Avatar
Motormouth
a quaife is a gas discharge from a female's vagina.
lol, it is a brand of LSD. very nice unit.
check the F/S section. other memers with autos swap to 6mt final drive and sell thier pumpkins or swap. ditto on VLSD pumpkins. that is really the only source that isn't exensive. also junkyards if you can find them.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
