Oil cooler installed APS TT
Old Nov 6, 2006 | 04:04 PM
al v's Avatar
al v
Default Oil cooler installed APS TT
Was a little difficult , by the reduced space, but finally done......
Old Nov 6, 2006 | 07:45 PM
Gary King's Avatar
Gary King
Have you seen a benefit from this yet?
Old Nov 7, 2006 | 05:16 AM
al v's Avatar
al v
My oil pressure was raised , when the car is completely warm, to around 25-30 lb at idle, before the installation my oil pressure was around 15 lb.So, I assume that the oil have more viscosity produced by the reduced temp.
Old Nov 7, 2006 | 06:01 AM
THE TECH's Avatar
THE TECH
Is this some sort of kit or did you part it together yourself? I have the Stillen kit and it is very nice with its Setrab cooler.
Old Nov 7, 2006 | 06:42 AM
al v's Avatar
al v
I wouldn´t go with the Stillen, it will not fit with the APS TT.I get this kit from Ebay:
http://cgi.ebay.com/ebaymotors/PERFO...mZ320041201678
Old Nov 7, 2006 | 06:49 AM
THE TECH's Avatar
THE TECH
I don't have an APS kit, so no issues there. The Stillen kit is top quality with a much better cooler than that Ebay piece. Not sure what you mean by "it will not fit with the APS TT."
Old Nov 7, 2006 | 07:56 AM
al v's Avatar
al v
I was referring to my setup, the Stillen oil cooler kit will not fit ,if you have an APS TT installed...................
Old Nov 7, 2006 | 08:08 AM
IIQuickSilverII's Avatar
IIQuickSilverII
nothing wrong with stillen
my oil cooler set up installed by Intense, a lil custom work there for the bracket, very clean and safe install
Old Nov 7, 2006 | 08:18 AM
THE TECH's Avatar
THE TECH
^^Mine is in the exact same spot.
THE TECH's Avatar
THE TECH
Still don't know what you mean by it won't fit. Won't fit where?
Old Nov 7, 2006 | 09:13 AM
al v's Avatar
al v
I did see the pics, before buy any kit, of the Stillen installation instrucction, and if you see the pics, won´t fit with the aps oil pan , and the oil radiator won´t fit in this position, or even in your position , because the air filters are in there.............
Old Nov 7, 2006 | 09:24 AM
IIQuickSilverII
did you were mine was installed? do you see it being installed in the same position where the instructions say?, ovbiously is you are an "automaton" and you can't think outside of what the intructions say it will not fit.
doesn't take a lot of custom work to make it happen
Old Nov 7, 2006 | 09:33 AM
zman1910's Avatar
zman1910
Easy to talk when a shop did it for you Any other person (especially if they plan on doing it themselves) will look for something that will surely fit without any hassle....so you kind of have to look at the instructions first. Not everyone likes to modify or has the ability too. The OP never posted anything negative about the stillen oil cooler..just that it simply would not fit for his needs
Old Nov 7, 2006 | 09:36 AM
IIQuickSilverII
i was there when it was done.. they jsut looked at it and decided where it would fit... the main work was gettin those brackets to make it fit...
the whole point was to say that it does fit...and no major work was needed to make it work
Old Nov 7, 2006 | 10:22 AM
al v's Avatar
al v
Especially if you live in a country at more than 10.000 miles of distance , and you can not return , because the shipping cost, will be much more than the oil cooler cost.............
Old Nov 7, 2006 | 10:45 AM
IIQuickSilverII
did you have your car build in chile?
Old Nov 7, 2006 | 11:36 AM
al v's Avatar
al v
Yeap , everything was made here , by me and a friend.
We only have around 40 350Z in chile , and mine is the only one with a turbo kit...........
Old Nov 7, 2006 | 12:01 PM
IIQuickSilverII
question is who did the tunning down there? engine can be shipped
soy de peru por siaca, y solo 1 Z hay. ANd no hope to find a dyno...
Old Nov 7, 2006 | 12:06 PM
THE TECH's Avatar
THE TECH
I agree with Quiksilver. If you don't have a brain than nothing will fit unless it is perfectly built OEM. The Stillen would fit and work if you had wanted it to. Saying it doesn't fit tells people that it will not work at all. I have the Stillen and didn't install it where the manual said cause I have a Vortech and the FMIC is in the way. I made it work.
Old Dec 6, 2006 | 03:12 AM
CESAROTORRES's Avatar
CESAROTORRES
Default ARC Oil cooler with APS TT
Does any one know if the ARC oil cooler will fit with the ARC oil cooler?
Thx
Cesar
