Fuel pump fuse
Old Nov 12, 2006 | 08:58 AM
supra crazy's Avatar
supra crazy
Default Fuel pump fuse
I'm In he process of installing a new fuel pump but I cant seem to find where the fuse is located. It isnt in the use panel on the driverside ick plate nor is it in the battary compartment. Is there another fuse bx n the car?
Thanks
Old Nov 12, 2006 | 10:53 AM
DavesZ#3's Avatar
DavesZ#3
It should be the 15A fuse #81 in the IPDM box under the hood (by the battery).
Old Nov 12, 2006 | 11:07 AM
supra crazy
Thanks but the fuse box near the battery looks nothing ike that it is slim with not much fuses in it
Old Nov 12, 2006 | 11:23 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
you have to remove the plastic trim piece and then youll see a black cover, remove that and itll reveal the fuse. Its all the way at the bottom, blue.
Old Nov 12, 2006 | 12:55 PM
DavesZ#3's Avatar
DavesZ#3
I think you actually have to remove the battery to get to it.
Old Nov 12, 2006 | 03:39 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
You dont have to remove the battery, but you do need to remove the passenger side windshield trim piece. That should you get you there.
Old Nov 12, 2006 | 04:03 PM
QuadCam's Avatar
QuadCam
yup. remove the cover for the battery. then, remove the plstic trim panel that butts up to the windshield. Then you can see the black box. It is located back and toward the fender of the battery. Remove the black plastic cover by pull striaght up on it.
the fuse should be the top fuse on the right hand side of the panel.
Old Nov 12, 2006 | 05:42 PM
supra crazy
Thanks
kyin
Oct 15, 2015 05:54 AM
