RevUp Oil Consumption TSB and discussion
Dame it. i think im having to join this thread.. finally noticed a consid drop in oil between services.. dame it..
i should mention that it may have been due to them leaving the cap off (i know i lost some oil) but i just cant see me losing as much oil as i know i did.. i hope not..
Originally Posted by dbasal
Well. The parts department could not tell me what the difference between those two part numbers is. All they can say is that it is a Z engine.
Originally Posted by creationv2
my service manager says he thinks the M9 is for the g....kinda makes sense it looks like a g? lol maybe the MG was taken already.
Looks like I may need to give a call to the arbitration people and start demanding some answers to figure out what I have in my vehicle. They have to provide this information to prove the engine is different. Then again, they could always fake that.
It may be that someone needs to actually tear one apart and compare it to a v1.
Anyways, my receipt says:
10102-AC7MZ ENGINE BARE
Invoice Date is 5/18/2007
I have 10102-AC7MZ ENGINE BARE too.
Approx 1 qt between the L and the H. The dealer will tell you 3 qts is normal, but don't fall for it.
Thanks. I just called them and told them they are going to have to prove that my engine has different internal parts than my original as that was the deal to allow the final repair attempt. We'll see next week.
awesome! cant wait for the update next week then
in which ill also be putting my car in for shop.
The pinging noise is very faint in this engine. My last engine it sounded like the valves were pinging, this one I think I hear it pinging, but its very very faint, it could be mechanical in the throttle. I just know this was a problem because a few others ont his board had the same symptons.
If you start out in 2nd or 3rd gear you should hear a pinging, thats what I had all the time. It was ridiculous. In addition to burning 1 qt at 800miles.
I just hope this new engine is solution to our problem.
mh
My dealership's mechanic told me that National Nissan was keeping what they changed inside topsecret. And even he didn't know what they changed on the engine. There was a mechanic specialist from NNA to assist in the installation.
mh
mh
If this engine did not burn any oil, I would not be concerned, but we are starting to see these replacements burn oil also.
Hi guys
Jim here from sydney australia. I have posted here before and giot great help form all of you out there.
Just like you guys nissan australia finally changed my engine and yep part number is 10102AC7MZ just like you guys.
Mechanics who replaced my engine told me that problem with the oil consumption was caused by piston rings. He reckons they were placing ceramic rings on the bottom of the piston which was causing piston chamber to be polished and creating a gap between rings and walls causing oil to pass through. Havent explained it very well and my mechanical knowledge is poor but thats the explaination he gave me. Not saying I believe the bloke but will just wait to see if my oil consumption issues continue with this new engine.
Interesting to note that nissan australia kept on telling me that there were no other cases in australia but when my car was being done there were 2 others in the workshop also having engines replaced!!!!
Good luck to all, will let you know anything further from here in sunny sydney.
My non rev up 2003 G35 is also consuming oil. I'm losing about 1 quart every 1000 miles. Break-in was easy on the engine. I also have an oil catch can, but it doesn't come close to accounting for the amount of loss. I called the local dealership, and they said to take it in. I'll prob start my procedure in the next 2 weeks.
John
Originally Posted by antennahead
Now I am scared to give this part number to my mechanic. There seems to be some doubt as to whether we are actually getting V2 engines with revised pistons/rings. I would hope that is the case, as many other than dbasal have seen success with the recent engines. After the run around my mechanic got that was outlined in my earlier posts, it just seems NNA is content to give us smoke and mirrors.............. keep us off balance and maybe this fiasco won't cost them a fortune. I wonder how much it will cost them when someone's engine locks up in traffic from no oil and a fatality occurs? hmmmmmmmmmmmmmmmmmmm
John
John
yah and the sad part is theyll probably try to blame it on driver/owner's poor maintenance skills or soemthing.
well my car went in today for my new engine... hope this one works guys, im tired of looking at my utec, xo2 exhaust, random tech hi flows, mrev2, spacer, unorthodox pulleys, unorthodox flywheel, and pop charger here in my room lol.
John
