Need help: Can't get into 5th gear properly & the whole neighborhood can hear me
Old Dec 20, 2006 | 08:53 PM
Cloud's Avatar
Cloud
Default Need help: Can't get into 5th gear properly & the whole neighborhood can hear me
I had the JUN flywheel & nismo clutch installed today at 2visions.
Jeff was great and I highly recommend him to all of you in norcal.
Took me 5 mins to get used to the super low grabbing point of the clutch.
However I have some issues with shifting. The car would not go into 5th when i push it to the far right and up. I have to push it to the far right, hit a notch then push it abit left. it seems like something is blocking the right side.
I find this very disturbing as having to push the shifter towards 3rd to let it slip into 5 is a misshift waiting to happen. A couple of times i tried to revmatch from 6-5 i ended up hitting the blockage and grinding the clutch. This takes a huge toll in my confidence of shifting from 6-5. I always fear a misshift.
Jeff thinks its normal for the nismo clutch. He's very knowledgeable but somehow I don't think it is. I would appreciate if anyone could tell me more about this.
Also the clutch chatter extremely loud, louder than my exhaust at WOT
Does the clutch affect chatter or is the flywheel the only determining factor? All the reviews for the JUN flywheel says that its extremely quiet, one of them was paired with the ACT another was paired with clutchmasters fx300.
starting in 1st, clutch chatters but not too loud
2nd, chatters at 2-2.1k rpm(loud)
3rd, 2k rpm( Super loud)
4th, 2k rpm (loud)
5th, 2k rpm cruising just a tiiiiny bit of accel( extremely loud ! can be heard in a 1/4 mile radius maybe )
Appreciate all the advice and help I can get.
and thanks to Jeff for the wonderful install.
Old Dec 20, 2006 | 10:38 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
I had the same problem after my jwt clutch and flywheel install. I got used to it so its not really a hassle for me anymore. One thing i also noticed is that i dont have to push down on the shifter to go into reverse either, does yours do that? I dont know if something is broken or not. Kinda wierd. Doesnt really affect anything for me anymore tho
Old Dec 20, 2006 | 10:40 PM
Cloud's Avatar
Cloud
I have no idea.. so were u able to get into 5 smoothly?
Old Dec 21, 2006 | 04:29 AM
JG 350Z's Avatar
JG 350Z
Your shifter guide plate needs a slight adjustment. Its too far over to the right, easy fix. look here...
https://my350z.com/forum/showthread....highlight=****
Old Dec 21, 2006 | 06:50 AM
jdm3fiddyZ's Avatar
jdm3fiddyZ
wow, thanks man! i gotta get on that this weekend then.
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
May 30, 2017 03:28 PM
Depravity
Oct 1, 2015 04:49 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
