350z Grounding?
Old Jan 2, 2007 | 03:51 PM
Riyazsf's Avatar
Riyazsf
Default 350z Grounding?
Im thinking of my first mod to be a grounding kit. I have found this online--> http://www.2kracing.com/product_info...oducts_id/5531
. I just wanted someones opinion. is this a good mod? i've found other kits for about 50 bucks but they're not 8 point kits. what do u guys think?
Old Jan 2, 2007 | 04:04 PM
ZCARBANDIT's Avatar
ZCARBANDIT
i dont know how good this one really is but i have heard of people buying cheaper grounding kits and not having the right lengths, and missing certain pieces. I would pay the extra money and go with a stillen or something along those lines.
Old Jan 2, 2007 | 04:44 PM
Riyazsf's Avatar
Riyazsf
Thanks for the piece of info. I hadn't heard of anything like that but i could see it happen. Im now looking at stillen and hks. any pref? or any other brands?
Old Jan 2, 2007 | 04:47 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Sun Automobile makes grounding kits and also has the Cyberspeed version that is vehicle specific to our Z's. They make the NISMO kit for our cars and are OEM suppliers for Toyota etc in Japan, which shows you their level of quality with ISO-14001 certification.
Old Jan 2, 2007 | 05:55 PM
Ichigo's Avatar
Ichigo
There's plenty of install instructions floating around on the net that give you the exact lengths you need and where to connect them.
Here:
http://z-xtreme.com/installation.html
Old Jan 2, 2007 | 06:49 PM
rocks's Avatar
rocks
Just get some 4 gauge wire and some wire connectors and make your own for 20$. Or buy some snakeoil. Grounding kits make me laugh.
Old Feb 17, 2007 | 09:17 AM
DanielW's Avatar
DanielW
what exactly would a grounding kit accomplish that would put ANY more power to the wheels?
Old Feb 17, 2007 | 09:43 AM
Eazzy's Avatar
Eazzy
Probably nothing, I run one and have been in the habit of "over" grounding for yrs, whether it be a house, a welder or a custom build on a car because grounding is so important to the system as a whole. Plus, it's a good backup if the OEM grounds start to fail,which they tend to do. Most cars are grounded to the minimum,---one corroded/loose ground and ur dead in ur tracks til a long hard search finds it.
Old Feb 17, 2007 | 09:54 AM
WalkerT's Avatar
WalkerT
Professional
I have seen test that show a 5 hp loss. Look at the current issue of nissan sport ( the mag that replaced sport z). They did dynos and showed a loss of power on the Z.
Old Feb 17, 2007 | 12:55 PM
Steve-O Z33's Avatar
Steve-O Z33
Magazines saw a 1 HP loss or gain... like they said, it's within dyno error. I put a kit on my car. No difference really. Lots of people say it helps throttle response. I can't tell. I'm hoping to dyno my car Saturday but I've got a few other mods than just grounding wires.
Old Feb 17, 2007 | 01:03 PM
Eazzy's Avatar
Eazzy
Thats my point ---They do one thing and one thing onlt ---Beef up ur existing ground system that contols EVERY thing Elec in ur car ---Its a non performance peace of mind thing
Old Feb 17, 2007 | 01:45 PM
WalkerT's Avatar
WalkerT
Professional
I have some snake oil you can buy that will give you a 2-5hp gain and try to prove it does not work. This is my point companies use errors to miss lead the public. If you want to upgrade the grounds on your car just sand the paint off under the factory ground points and make sure they are all tight. You can also put a multi meter on them while the engine is running and check the ohms. If you need the peace of mind of putting huge wires on then go ahead. I have dynoed my car 6 times and I can very each run by 5hp just by small differences. Like shut the hood and turn off the fan and 5hp gone due to heat soak then open the hood turn on the fan (the one they put in front of the car while on the dyno) and wow 5hp gain.
In the end it is your call this is just my .2 cents and enjoys your grounding kit.
Old Feb 17, 2007 | 01:52 PM
Steve-O Z33
I wouldn't dyno without a fan in front of the car. That's pretty much auto abuse.
Old Feb 17, 2007 | 01:56 PM
WalkerT's Avatar
WalkerT
Professional
I was just using that as an example and I dont not recommend it.
Old Feb 18, 2007 | 04:41 AM
ncparamedic's Avatar
ncparamedic
Prodigal Son
Who is the member that used to make the grounding kit for the z's back about a year ago. Is he still around. His kits looked nice.
Old Feb 18, 2007 | 05:02 AM
Eazzy's Avatar
Eazzy
I REPEAT --------There are NO HP gains. But I have over 30 yrs seen too many systems fried ( Like EVERY wire melted together under the dash ) because of factory grounds, and OEM grounds suk, the wire is to lite a gauge and the connecting points are prone to loosen and corrode ( 10 times more so after they heat up a few times due to their indaquite sizing and connections ) Its a vicious circle -----Grounds get hot,are more prone to corode and loosen, which in turn causes them to get hotter --etc etc
Point is ---WTF ----cover ur ***, and do it for ur car. Too much thats important is ignored because it doesnt make HP----HP is useless if ur elec system is a molten mess.
Old Feb 18, 2007 | 05:05 AM
Eazzy's Avatar
Eazzy
He was from Austin --- I forget ---Do a search under Inventions
Old Feb 18, 2007 | 03:01 PM
WalkerT's Avatar
WalkerT
Professional
Like I said enjoy your gounding kits. How will all the Z's out there that dont have them survive
Old Feb 18, 2007 | 04:04 PM
Eazzy's Avatar
Eazzy
Dont be Confused---Take a couple deep breaths. They will survive just fine. If he wants to use a grounding kit, no harm done. If he doesnt and a 1 in a 5000 fluke happens, then he will be thankful.
Its preventative maintenence for an unlikely occurance---Its the poorly installed after market components like big amps that hurt u and its great to tie into ur kit for grounding
Old Feb 18, 2007 | 06:07 PM
Tortuga's Avatar
Tortuga
HarvesterUT was his name. I bought my kit from him.
Here is his profile, shoot him a PM.
https://my350z.com/forum/members/38597-harvesterut.html
