Sluggish performance around corners (AT)
Old Jan 15, 2007 | 03:30 PM
psytropic's Avatar
psytropic
Default Sluggish performance around corners (AT)
With the TCS off if I am taking a corner and give it gas, it's like the engine pauses then it decides to downshift....
UPDATE: Earlier today I gunned it going straight and it did the same thing...
Should I get the car checked out for codes??
Old Jan 15, 2007 | 03:50 PM
dTor's Avatar
dTor
Just reset the ecu. It is in it's "I've learned not to drive fast" mode. You need to clear the learned ecu values. After you do, get out and do a few WOT runs (pref on the interstate), so that it will learn to downshift faster.
Old Jan 15, 2007 | 05:47 PM
chingwithbling's Avatar
chingwithbling
Or just pop it in tip and choose the gear you want.
Old Jan 15, 2007 | 05:52 PM
stein's Avatar
stein
+1
I know around here being stuck in traffic 95% of the time the computer forgets how to get up and go at times. Just slide it over to manual mode and enjoy!
EnjukuRacing
Sep 30, 2015 06:55 AM
Tochigi_236
Sep 27, 2015 03:40 PM
