HELP.....OBD2 Code Reader, Reading P1122
Old Feb 1, 2007 | 06:53 PM
johnnywall22's Avatar
johnnywall22
Default HELP.....OBD2 Code Reader, Reading P1122
I was driveing my car home from walmart and my Z started to f*** up. Dont know what is going on its like you pushing the gas pedal and then letting off. I have a OBD2 Code Reader and it is reading p1122 and the book that came with it says it a "Pedal Position Sensor A Circuit Low Input". Has this happen to any one here and can any one give some adv. on what it maybe doing.
Thanks
Trey
Old Feb 1, 2007 | 07:17 PM
johnnywall22
Help???
Old Feb 2, 2007 | 06:12 AM
Q45tech's Avatar
Q45tech
Study your downloaded copy of FSM. Each code has a look up and test and repair proceedure.
http://www.phatg20.net/modules.php?n...ownload&cid=68
Old Feb 2, 2007 | 06:14 AM
jpc350z's Avatar
jpc350z
Throttle position sensor problem??
Old Feb 2, 2007 | 10:10 AM
ZCARBANDIT's Avatar
ZCARBANDIT
Harness or Connectors(throttle control motor circuit is open possibly or shorted out)
Or the throttle control actuator.That comes with the entire throttle body.
PM sent.
If you have that the throttle valve will be maintained at about 5 degrees by the return spring.
Old Feb 2, 2007 | 02:05 PM
johnnywall22
Thank you but has this happen to any one here.
apex locator
Jul 23, 2021 02:27 AM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Tochigi_236
Sep 27, 2015 03:40 PM
