z using coolant
Old Feb 1, 2007 | 09:22 PM
wesismyhero's Avatar
wesismyhero
Default z using coolant
so i can fill my resevoir up to max and about two weeks later its at the minimum line. how can i check to see what the problem is? would the nismo radiator cap make a difference?
Old Feb 2, 2007 | 05:15 AM
booger's Avatar
booger
Is there a puddle under tha car ? Is there smoke coming out of the exhaust ? Did you check your oil ? If so....is it a milking grey ?
Old Feb 2, 2007 | 06:00 AM
THE TECH's Avatar
THE TECH
Did this just happen once or is it happening all the time?
Old Feb 2, 2007 | 06:08 AM
Q45tech's Avatar
Q45tech
Coolant system pressure tester is a mandatory tool in any Master Tech's box.
Old Feb 2, 2007 | 07:46 AM
Jason@Riverside's Avatar
Jason@Riverside
Vendor - Former Vendor
That tank will eventually re-circulate that coolant back into the system... If you had an air bubble in there it will bring it back in...
The best way to fill up with coolant will be to take off the radiator cap, put a funnel in there... add coolant to the funnel and leave the car running for a while... it will SLOWLY bring in coolant... if it gets really low, then add a little more if needed, but after about a half hour, if you are left with a full funnel, then your filled up...
If you are afraid of actualy burning up some coolant, take your car to a dealer / shop and get a pressure test done...
Old Feb 2, 2007 | 07:52 AM
ANXIOUZ's Avatar
ANXIOUZ
FWIW the last time I had my oil changed my coolant was low. I had just made a 1k mile trip so I suspect that had something to do with it but I dunno. So far it's been fine.
Chris350z03
Oct 8, 2023 07:19 PM
SharX59
Sep 27, 2015 09:23 AM
EnjukuRacing
Sep 18, 2015 07:57 AM
smithmt3
Sep 11, 2015 08:25 PM
