Just installed CUSCO type-RS LSD with 3.7 Gears
Old Feb 9, 2007 | 08:58 PM
OCG35's Avatar
OCG35
bump
Old Feb 10, 2007 | 03:52 AM
MustGoFastR's Avatar
MustGoFastR
Originally Posted by jtgli
Hey andy you said that the 3.7 dropped right in. So Im assuming then that you didnt need to replaced any bearings or shims or anything at all correct? I am thinking about doing this to my 06 revup. Will it drop right in as well with out anything else?
Whenever you change the ring gear and pinion, the shims will need to be changed/adjusted/set to that particular gear set. It's recommended that you replace the bearings if you have over 30k miles or so (as long as you're in there), but it isn't absolutely neccessary.
Old Feb 10, 2007 | 08:42 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Originally Posted by BloMyS14
Why did you go with the Cusco instead of the Nismo? I'm torn between the two right now. I like the Cusco because it's quiter, but I like the Nismo because I can install it myself and it's easy to adjust locking %.
? install on either a Cusco or NISMO is the same
adjusting them is also the same
internally they are not the same though (been discussed)
Old Feb 10, 2007 | 01:11 PM
AboostedG's Avatar
AboostedG
Twin Spoolin
Do you lose your Cruise Control with this?
Old Feb 10, 2007 | 05:01 PM
BloMyS14's Avatar
BloMyS14
So they both have to be shimmed?
Plates must be removed from both to adjust lock %?
Old Feb 10, 2007 | 06:59 PM
Z1 Performance
Former Sponsor
install on any of the LSD's is the same, regardless of maker. It is not easier nor harder to install 1 or another
the NISMO and Cusco diffs are very similar, though the Cusco is far smoother to engage and far quieter. To change lockup, you must rarrange the disk plates. To change LSD action from 1.5 to 2 way, you simply turn the "cam" (accessible from the outside of the diff my removing one of the output shafts)
The primary advantage the NISMO has vs the Cusco is only applicable, IMHO, to base owners, as the NISMO comes with the parts needed for the conversion. The Cusco requires extra parts (all layed out on our website,and we do packages that come with all that is needed).
http://www.z1auto.com/prodmore.asp?m...ine&prodid=518
But, it's how the 2 diffs behave in the real world that set them apart.
Old Feb 10, 2007 | 07:05 PM
BloMyS14's Avatar
BloMyS14
Gotcha. I have a track so I don't need the stub axles. What's in the installation kit?
Old Feb 10, 2007 | 07:07 PM
Z1 Performance
Former Sponsor
if you have anything except a base, no other parts are needed to install the diff.
Old Feb 10, 2007 | 07:15 PM
BloMyS14's Avatar
BloMyS14
The Cusco is sounding better the more I read about it.
Old Feb 10, 2007 | 08:17 PM
o snap its eric's Avatar
o snap its eric
I've been doing research, nismo lsd comes with everything you need for ~$1100. The cusco rs lsd with all the parts you need for the install for the base model is ~$1300. Now the $200 difference if its worth to you will give you a quitier lsd and "smoother" engagement. Although with the nismo, add in the right diff oil your lsd is suppose to sound like stock but the engagement is more aggressive. That i can live with, its just the matter of adjusting and refining your driving.
So it really depends how much you want to spend if you have a base. If you dont have a base its a no brainer to go with the cusco rs lsd.
Old Feb 12, 2007 | 07:36 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
I actually did replace all my shims and seals. I figured since Im tearing it apart anyways, it wont hurt to replace them and keep the car maintained. The 3.7 ring and pinion will drop right in.
Old Feb 12, 2007 | 07:37 AM
Andy@Performance
Performance Nissan
Originally Posted by davids
What can you expect this type of setup to run you? I have an LSD setup in my near future and I'd like to know what options there are.
Thanks!
As far as cost wise? Well besides the ring and pinion itself, the other replacement parts shouldnt run you anymore than $200-$300 depending on if you have a VLSD or non LSD.
Old Feb 12, 2007 | 07:38 AM
Andy@Performance
Performance Nissan
The CUSCO was more suitable as my car is a daily driver and I needed something slightly more quiet. Plus I have the CUSCO on special right now for much cheaper than the NISMO.
Old Feb 12, 2007 | 08:04 AM
rocks's Avatar
rocks
What year and make of nissan do the 3.7 come out of? I bet i can find these cheap in a junkyard. If these did come out of a nissan truck there are lots of aftermarket gears made for frontiers.
Old Feb 12, 2007 | 08:13 AM
trey.hutcheson's Avatar
trey.hutcheson
Is this the same rear-end being used by the new 07 g35 sedans?
Old Feb 12, 2007 | 09:22 AM
rocks's Avatar
rocks
Part Number Search Results : Mechanical Catalog
Item Number MSRP Core Price Price
381000C760 $551.84 $0.00 $441.48
Universals & rear axle - Rear axle - Differential - Ring & pinion
Ring and pinion, frontier, 2.5l, manual trans - frontier 2005 - 2006
Old Feb 13, 2007 | 01:19 PM
peptidbond's Avatar
peptidbond
Holy cow! That is a nice price for a 3.7, even if it ain't a 3.9.
As for Andy's setup, here is some math that I THINK is correct:
3500 engine rpm = 3889 driveshaft rpm if in 6th gear and ratio is 0.90:1 = 1051 tire rpm if gearing is 3.7.
Since Andy's tires are 255/35-19, that would be 81.8 inches per rotation, or 7164 feet per minutes.
This actually equals 81.41 miles per hour. However, make sure the gear ratio I quoted on 6th gear is correct.
This really seems very high to me?!?!
Old Feb 13, 2007 | 01:21 PM
  #38
sentry65's Avatar
sentry65
the burninator
6th gear is .794
Old Feb 13, 2007 | 02:13 PM
  #39
Andy@Performance
Performance Nissan
Originally Posted by SMarinoZR
It was a heck of a deal too
Any idea when mine is going to be sent out?
Im waiting on one more bearing to come in which should be this week and it will be shipping out!
Old Feb 13, 2007 | 02:15 PM
  #40
Andy@Performance
Performance Nissan
Ive been racking my brain on this as well and I cant figure out why my RPM's are so high. I have no complaint though cause acceleration seems to be an improvement.
