arc oil catch tank install
Old Feb 8, 2007 | 11:08 AM
jdm_350's Avatar
jdm_350
Default arc oil catch tank install
can anyone do a write up about this catch tank? this is for the first gen arc oil catch tank.
Old Feb 12, 2007 | 11:55 PM
jdm_350's Avatar
jdm_350
anyone????????
Old Feb 13, 2007 | 05:25 AM
InjectedPerf's Avatar
InjectedPerf
Injected Performance
I have one in stock if you would like to be the first
Old Feb 13, 2007 | 05:39 AM
Mike Wazowski's Avatar
Mike Wazowski
make me a good deal and I will do the write up LOL
Old Feb 13, 2007 | 05:45 AM
THE TECH's Avatar
THE TECH
Do a search. There are already several threads on this.
Old Feb 13, 2007 | 06:30 AM
MasterRacer's Avatar
MasterRacer
^^ lmao love that puss
Old Feb 13, 2007 | 07:31 AM
Kwame's Avatar
Kwame
Did yours not come with instructions? The instruction included are very thorough.
Old Feb 13, 2007 | 08:20 AM
jpc350z's Avatar
jpc350z
Make sure the holes on the top hat are closed off (weld) or you will smell oil vapors..And it helps to collect the manifold vapors if you connect a vac line to the can..This also requires an additional hole and port welded to the can. AAM sells it with the holes welded and a port added..Good luck
Old Feb 13, 2007 | 08:21 AM
THE TECH's Avatar
THE TECH
You don't HAVE to do that unless you're running FI.
Old Feb 13, 2007 | 08:36 AM
jpc350z's Avatar
jpc350z
If you have manifold vapors going into the can , they will escape into the engine bay and into the car...How do you capture and keep them in the can???
Old Apr 18, 2007 | 09:07 AM
VO...'s Avatar
VO...
Administrator
Does anyone know if the new design(V2) rectified this?
Old Apr 18, 2007 | 09:09 AM
bbs350z's Avatar
bbs350z
idk but the new design is badass!
Old Apr 18, 2007 | 09:26 AM
VO...'s Avatar
VO...
Administrator
It does look pretty nice. I'm thinking about picking up one. I've been researching as much as possible on this item. Bling is one factor, but I also want to avoid caking up my intake manifold with oil/sludge. 2 months ago I replaced my upper plenum. When I took it off, I noticed there was a nice coat of oil in there. I ended up cleaning it out with a rag, but would like to avoid this in the future.
Old Feb 2, 2013 | 05:40 PM
nismo4life11's Avatar
nismo4life11
I am in need of instructions for the v1 catch can also been searching on this site for hours and only find all the universal cr** anyone got diagrams or pics or anything? And I know I'm bringing back an old thread but I don't wanna get cussed out for not searching when I have.
Old Feb 6, 2013 | 09:53 AM
VO...'s Avatar
VO...
Administrator
^^You did the right thing by bumping an old thread. Let me see if I can search and find one...
Old Feb 6, 2013 | 10:06 AM
VO...'s Avatar
VO...
Administrator
Good luck there grasshopper. Even with my JDM searching skills, I still couldn't find anything. Not here, on the net, or on Youtube...
Old Feb 6, 2013 | 10:54 AM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
It's not too bad. There's two lines that are routed to the valve covers. Ones attached to the intake tube underneath. It's the only line attached. The intake manifold has an L shaped nipple. Use the associated metal extension and lines and route to the Y fitting. Everything else is self explanatory I think, maybe I should just take a pic.
Old Feb 8, 2013 | 11:02 AM
nismo4life11
Thanks vo7848 I try not to **** mods off but this one really stumped me to. Vq.turbo.dremz thanks for the reply pictures always help but if I'm getting this right the line comes from the catch can and attaches to the "y" piece, then from the "y" one line goes to the previously hooked up valve cover to intake tube and the other goes to the just the intake tube? Sound right?
Old Feb 18, 2013 | 07:44 PM
serges's Avatar
serges
I jist picked up a v1 can and I have a hole drilled in the hat? Should I plug it all so it doesnt smell and will this work on my 06 g coupe aswell? And im also looking for install help, if indeed can install on my revup g? Thanx sorry for bumping old thread...
Old Feb 19, 2013 | 05:50 AM
350zjason350z's Avatar
350zjason350z
Know it all
I just bought the v1 and maybe it will come with instructions... It's supposed to be brand spanking new
