Factory hp loss to drive train? Any stock dynos?
on
Is there a general concenses as to the hp loss between crank and wheel with a stock 03-05 350Z? I think I dyno'ed at 235 pretty stock with my 03'. Any others dyno stock cars. Is there a better answer to this question than comparing the stock dyno numbers to the given 287 crank hp rating?
I did a search and cant find anything. ANy help would be great. Thanks.
on
Originally Posted by robbycolli
thanks moflow. i'm calculating 18% loss. does that seem right to you all?
for MT; I guess 10% or so.... If you are AT I'd say 18% is a good conservative legit percentage...
on
Frictional losses vary with rpm and lube/tire temperature, diff are extremely lossy until 10 mph and optimized for 55 mph. In fact everything is optimized for 55-65 mph to squeeze every 0.001 mpg on epa dyno test.
Tires are the highest individual component, then comes the TC, alignment [rear toe and cambers], then diff, driveshaft, AT pump, halfshafts, AT gear mesh.
The point is every car will have a different loss, give or take a few percent.
Finally some go
Originally Posted by GG_VQ
AT or MT?... I usually calculate about 15-20% for my AT G, although I've heard some say as much as 25%...
Most non-revup VQ dyno btw 230 to 240 whp on MTs. Which is a 16 - 20% loss. 10% is way too low.
FWIW my MT Z dynoed bone stock a 239 whp on a Mustang Dyno SAE corrected.
Originally Posted by RBlover69
what we need to do is find out how porshe has such a low drivetrain loss.
This is why transaxle cars like front drives and mid drives have 10-12% parasitic loss on average, and front engine-rear drives have 15% parasitic loss on average. AWD cars will have a higher parasitic loss due to more drivetrain components, on average round 20%.
I dynoed my bone stock 03 base at 239whp on a DynoJet.
Will
Will
Will
on
Originally Posted by Sunset350ZR
I have always heard drivetrain losses are actually greater on FWD cars.
on
Originally Posted by dutchboy350Z
You'll never see a bone stock 03'-05' non revup 350Z dyno @ 259 whp (10% loss).
Shift_Boost
on
Most dynojets I'd say 18-20%. Ran mine on a dynapack not too long ago and was sitting at 238whp....that's with breather mods and a UTEC....so I'd say 20-25% on a properly setup dynapack. I'm at sea level btw.
11-09-2020 10:27 AM
350Z_Al
10-29-2020 07:44 PM
