Why such big HP & TQ difference
Old Apr 8, 2003 | 10:46 AM
MarkoBarko's Avatar
MarkoBarko
Default Why such big HP & TQ difference
Why is the dropoff so great between HP/TQ at the crank and at the wheels? Advertised is 287hp and rwhp is 220-230. Same thing with torque. That is a huge dropoff in power.
The WS6 has 325 and rwhp is around 305-310. This is a lot more reasonable.
Why are we having such a large drop?
Old Apr 8, 2003 | 10:55 AM
lEtMeZ1's Avatar
lEtMeZ1
dynos stock are looking more like 230-240.... Every car has a loss from the flywheel(287) to the wheels(230-240?) through the tranny, drivetrain, etc... If I am right I believe that FWD vehicles lose about 15-20% RWD lose about 20% and AWD around 20-25% to the wheels. All cars advertise the HP at the fly.... for example the RSX type S advertises 200HP but when dynoed is really about 170 give or take a few HP. It's not just the VQ's its all engines.
Old Apr 8, 2003 | 11:02 AM
VandyZ's Avatar
VandyZ
Originally posted by VQracer
Someone correct me if I'm wrong but I believe that the WS6's horsepower numbers are underrated from the factory.
Yeah, you could say that! Most all chevy's are. They are smart that way.
Old Apr 8, 2003 | 11:38 AM
350zSpeedRacer's Avatar
350zSpeedRacer
Actually, the reason the FBodies were under rated is because there's no point in paying 45k for a Vette when you can get the same power from a Camaro or TA for less than 30K?
You'd be surprised how many people didn't know the two cars had the exact same engine.
Old Apr 8, 2003 | 01:38 PM
FLY BY Z's Avatar
FLY BY Z
Yeah plus Ford had some problems with the Cobra that they claimed put out 305 HP but it didn't. Better to underrate than overrate. With the Z you are seeing a true rating and true loss of power as a result. 17% drivetrain loss is avg. for a RWD car so we are ok. We just need to figure out how to actually make some power...
Old Apr 8, 2003 | 03:30 PM
Traffic's Avatar
Traffic
Default Re: Why such big HP & TQ difference
I actually dynoed at 246. What I want to know is why numbers are all over the place. I figure any set of engines should dyno within +-3%, is that fair? But I've seen from 220 up to 246-8. That's more like a 6-7% difference.
Old Apr 8, 2003 | 03:42 PM
mcclaskz's Avatar
mcclaskz
Different dynos, different conditions, different testing situations. There are few controls between what people are dynoing across the country.
Old Apr 8, 2003 | 04:01 PM
dr_gallup's Avatar
dr_gallup
The dyno's used by speed shops are not particularly accurate. I never heard of any speed shop owner actually calibrating one of those things. Engine manufactures and laboratories like SouthWest Research that do EPA certification spend a lot of time and money making their million dollar dynos accurate and repeatable. When I did diesel engine developement 25 years ago we could get the same engine to measure within +/-1% in 2 different test cells but only after rigorous calibration.
Also, there is a pretty good spread in engine output with all the hundreds of tolerances on all the parts that make up an engine and drive train. Thats why show room stock racers blueprint their engines. If you get all the tolerances to add up on the plus side for power output you can have a "stock" engine that puts out significantly more power than one assembled from random parts. Additionally, there is definately some breakin going on. Most cars today perform better after 10 or 20 thousand miles than they do new. A lot of the dyno curves published were on engines right after they got through the 1200 mile breakin period.
Old Apr 8, 2003 | 06:16 PM
bfleming's Avatar
bfleming
Default Blueprinting
I've seen the term bluprinted used in lots of auto mags and never seen a good explanation of the process. How is it done and how are tolerances checked.
Also, it would seem to me that there are about a gazzillion variables betweeen dyno runs that would explain differences of 5% or more - temperature and fuel being biggies.
Old Apr 8, 2003 | 06:25 PM
ares's Avatar
ares
Veteran
to be honest... Ive been in a plant, and for the initial runs, they are really still figuring stuff out... as in the grinding wheels they use to grind the cam shaft and all sorts of other engine components can wear down too quickly and throw off the measurements eventually they get it all set of properly, but at the beginning the peices can come off differently. they keep them within the allowable tolerances, but that can lead to slightly different numbers.
of course conditions and equipment can vary as well.
Old Apr 17, 2003 | 06:28 AM
MarkoBarko's Avatar
MarkoBarko
are there any mods that can be done that minimize this loss?or is it that these mods are too expensive to be worth it?
Old Apr 17, 2003 | 06:36 AM
westpak's Avatar
westpak
SFZCC
Yes and Yes. Basically look at any component between the engine and the wheels to help improve efficiency. We already have a Carbonfiber driveshaft so the only things left are Fly wheel and differential and to a small extent fluids.
Old Apr 17, 2003 | 12:23 PM
terahz's Avatar
terahz
Isn't the Pontiac a live axel car? The Z is an independent suspension. The Z has 4 universals of loss in the rear end.
Old Apr 17, 2003 | 02:17 PM
Z350Maniac's Avatar
Z350Maniac
TRUE!
On the difference in the numbers:
The difference is caused by a number of things. When a car manufacturer dynos the car at the crank (pretty neat process) they're getting power RIGHT FROM the engine. The engine is doing no work (i.e. moving a car) other than turning a crank. Put on a transmission and now you're moving an entire drivetrain. Add accesory items (i.e power steering, air conditioning) that require belt driven power and you lose some more power from what the original crank number was. Long story short: The dyno we run on takes power readings from the wheels (loss of power because of accessories and drivetrain (transmission)) the car manufacturer's take their readings from the crank because it is a constant value that has a controlled reading. If they took readings from the wheels there's ALL kinda of things that could factor in and make the numbers change. Hope this helps some.
FWD cars lose less because their drivetrain isn't spread from a transmission to a differential. Tha tranny does the work.
RWD loses more because the power is sent through the tranny to a differential gear to move the power to the wheels.
AWD loses the most (but makes up for this as it can transfer more of the left over power to ALL 4 wheels and make for some GREAT launches.) because of it turning a differential and a crankcase.
Old Apr 17, 2003 | 03:57 PM
joeshow750's Avatar
joeshow750
Changing your fluids (oil,diff,trans) to some high-end stuff can help a bit with drivetrain loss. I noticed a slight increase in gas mileage when I changed from regular/dealer oil to Mobil 1.
Old Apr 17, 2003 | 04:02 PM
Z350Maniac's Avatar
Z350Maniac
I COMPLETELY overlooked this post. My thoughts:
Lightweight underdrive pullies (i.e. alt./power steering/etc.) ,lightweight crank pully, lighter flywheel, transmission regearing, differential 'tweaking'. Just to name a few. I KNOW alot of these parts aren't available YET, but I can almost gaurantee you they will be out soon.
Old Apr 17, 2003 | 07:24 PM
Ben Davis's Avatar
Ben Davis
Don't forget lighter rims! And not stepping up rim size will help too!
Ben
Old Apr 17, 2003 | 07:25 PM
Z350Maniac's Avatar
Z350Maniac
Ben
VERY true. an 18 is IDEAL for the Z's going bigger messes a bit with the performance. As was mentioned, if you can take 6 lbs. off each rim and 2-3 lbs. of each tire yer gonna get alot more on the road.
Old Apr 18, 2003 | 06:46 AM
supra crazy's Avatar
supra crazy
correct me if im wrong but i thought we had a carbon fiber reinforced drive shaft i went under my car and it looked like the carbon fiber was wraped around the drive shaft
Old Apr 18, 2003 | 06:52 AM
FLY BY Z's Avatar
FLY BY Z
Key word, reinforced, huh?
